i am trying to write driver for imx219 sensor, everything is fine until i run command to stream video
This is log with cmd: [root@luckfox root]# v4l2-ctl --device=/dev/video0 --set-fmt-video=width=480,hei
ght=320,pixelformat=RG10 --stream-mmap --stream-to=video_0.raw --stream-count=10
what files do i have to check and edit to make it work with imx219 ?
[ 632.220364] imx219 resume
[ 632.220385] imx219 power_on
[ 632.228241] stream_cif_mipi_id0: open video, entity use_countt 1
[ 632.229568] rkcif-mipi-lvds: stream[0] start streaming
[ 632.229696] rockchip-mipi-csi2 mipi0-csi2: stream on, src_sd: 91ca180b, sd_name:rockchip-csi2-dphy0
[ 632.229710] rockchip-mipi-csi2 mipi0-csi2: stream ON
[ 632.229756] rockchip-csi2-dphy0: dphy0, data_rate_mbps 912
[ 632.229785] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0, ret 0
61440 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0[ 632.880680] RK630 PHY stmmac-0:02: failed to read out thermal zone (-11)
!= 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
< 15.00 fps
0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0[ 697.870688] RK630 PHY stmmac-0:02: failed to read out thermal zone (-11)
!= 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
< 15.00 fps
0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0 != 245760
<0[ 698.865684] rkcif-mipi-lvds: stream[0] start stopping, total mode 0x1, cur 0x1
!= 245760
<[ 699.370496] rockchip-mipi-csi2 mipi0-csi2: stream off, src_sd: 91ca180b, sd_name:rockchip-csi2-dphy0
[ 699.370519] rockchip-mipi-csi2 mipi0-csi2: stream OFF
[root@luckfox root]# [ 699.370543] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 699.370560] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0, ret 0
[ 699.370861] rkcif-mipi-lvds: stream[0] stopping finished, dma_en 0x0
[ 699.371282] stream_cif_mipi_id0: close video, entity use_count 0
[ 699.371340] imx imx219_suspend
[ 699.371349] imx219 power off
Driver imx219 for pico pro max
We do not provide this camera device, you need to adjust it yourself. Currently, it seems that the reading has failed.
Thank for your response.
I would be really grateful if you let me know what to do and check where the current error is coming from
This is kernel log :
DDR 306b9977f5 wesley.yao 23/12/21-09:28:37,fwver: v1.15
S5P1
4x
OTP null
ff67
rgef1
DDRConf2
DDR3, BW=16 Col=10 Bk=8 CS0 Row=14 CS=1 Size=256MB
924MHz
DDR bin out
U-Boot SPL board init
U-Boot SPL 2017.09 (Jan 10 2025 - 22:18:28)
unknown raw ID 0 0 0
Trying to boot from MMC2
ENVF: Primary 0x00000000 - 0x00008000
No misc partition
Trying fit image at 0x440 sector
## Verified-boot: 0
## Checking uboot 0x00200000 (lzma @0x00400000) ... sha256(9e9dc7649a...) + sha256(82e54ea579...) + OK
## Checking fdt 0x00260998 ... sha256(9f596c5683...) + OK
Total: 335.268/385.667 ms
Jumping to U-Boot(0x00200000)
U-Boot 2017.09 (Jan 10 2025 - 22:18:28 +0700)
Model: Rockchip RV1106 EVB Board
MPIDR: 0xf00
PreSerial: 2, raw, 0xff4c0000
DRAM: 256 MiB
Sysmem: init
Relocation Offset: 0fd81000
Relocation fdt: 0edfa778 - 0edfede0
CR: M/C/I
Using default environment
no mmc device at slot 1
mmc@ffa90000: 0, mmc@ffaa0000: 1 (SD)
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: ENV
DM: v2
No misc partition
boot mode: None
RESC: 'boot', blk@0x00001db6
resource: sha256+
FIT: no signed, no conf required
DTB: rk-kernel.dtb
HASH(c): OK
Model: Luckfox Pico Max
## retrieving sd_update.txt ...
bad MBR sector signature 0x0000
** Invalid partition 1 **
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 924000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
aclk_peri_root 400000 KHz
hclK_peri_root 200000 KHz
pclk_peri_root 100000 KHz
aclk_bus_root 300000 KHz
pclk_top_root 100000 KHz
pclk_pmu_root 100000 KHz
hclk_pmu_root 200000 KHz
No misc partition
Net: eth0: ethernet@ffa80000
Hit key to stop autoboot('CTRL+C'): 0
## Booting FIT Image at 0xe90ab40 with size 0x002eec00
Fdt Ramdisk skip relocation
No misc partition
## Loading kernel from FIT Image at 0e90ab40 ...
Using 'conf' configuration
## Verified-boot: 0
Trying 'kernel' kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x0e913f40
Data Size: 3036840 Bytes = 2.9 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha256
Hash value: 419742e9a72d4474c51ce6dff54ab3d6aa63c31097e50b7214794e1ddff0be8b
Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at 0e90ab40 ...
Trying 'fdt' fdt subimage
Type: Flat Device Tree
Data Start: 0x0e90b340
Data Size: 35821 Bytes = 35 KiB
Architecture: ARM
Load Address: 0x00c00000
Hash algo: sha256
Hash value: db32659e4940b130a7a51cce12fdd5b5e490e8045f7a1beb139d11d6a5afeef1
Loading fdt from 0x0e90ab40 to 0x00c00000
Booting using the fdt blob at 0x00c00000
Loading Kernel Image from 0x0e913f40 to 0x00008000 ... OK
kernel loaded at 0x00008000, end = 0x002ed6a8
Using Device Tree in place at 00c00000, end 00c0bbec
Adding bank: 0x00000000 - 0x10000000 (size: 0x10000000)
Total: 838.275/1229.14 ms
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.160 (leevawns@leevawns-Latitude-E5470) (arm-rockchip830-linux-uclibcgnueabihf-gcc (crosstool-NG 1.24.0) 8.3.0, GNU ld (crosstool-NG 1.24.0) 2.32) #2 Wed Jan 1 14:54:39 +07 2025
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Luckfox Pico Max
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 67584 KiB at 0x0be00000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000000fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000000fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000000fffffff]
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: user_debug=31 storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal rootwait earlycon=uart8250,mmio32,0xff4c0000 console=ttyFIQ0 root=/dev/mmcblk1p7 snd_soc_core.prealloc_buffer_size_kbytes=16 coherent_pool=0 blkdevparts=mmcblk1:32K(env),512K@32K(idblock),256K(uboot),32M(boot),512M(oem),256M(userdata),6G(rootfs) rootfstype=ext4 rk_dma_heap_cma=66M androidboot.fwver=uboot-01/10/2025
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 185544K/262144K available (3793K kernel code, 379K rwdata, 1816K rodata, 196K init, 138K bss, 9016K reserved, 67584K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000016] Switching to timer-based delay loop, resolution 41ns
[ 0.000456] Console: colour dummy device 80x30
[ 0.000494] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000511] pid_max: default: 4096 minimum: 301
[ 0.000668] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000681] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001211] CPU: Testing write buffer coherency: ok
[ 0.001759] Setting up static identity map for 0x81c0 - 0x81f8
[ 0.002227] devtmpfs: initialized
[ 0.008468] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008619] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008643] futex hash table entries: 16 (order: -5, 192 bytes, linear)
[ 0.008725] pinctrl core: initialized pinctrl subsystem
[ 0.009767] NET: Registered protocol family 16
[ 0.010192] DMA: failed to allocate 0 KiB pool for atomic coherent allocation
[ 0.010688] Registered FIQ tty driver
[ 0.010991] thermal_sys: Registered thermal governor 'step_wise'
[ 0.010997] thermal_sys: Registered thermal governor 'user_space'
[ 0.011212] cpuidle: using governor menu
[ 0.023475] rockchip-gpio ff380000.gpio: probed /pinctrl/gpio@ff380000
[ 0.024219] rockchip-gpio ff530000.gpio: probed /pinctrl/gpio@ff530000
[ 0.024912] rockchip-gpio ff540000.gpio: probed /pinctrl/gpio@ff540000
[ 0.025623] rockchip-gpio ff550000.gpio: probed /pinctrl/gpio@ff550000
[ 0.026284] rockchip-gpio ff560000.gpio: probed /pinctrl/gpio@ff560000
[ 0.026374] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.035133] fiq_debugger fiq_debugger.0: IRQ uart_irq not found
[ 0.035153] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 0.035400] printk: console [ttyFIQ0] enabled
[ 0.035556] Registered fiq debugger ttyFIQ0
[ 0.036583] reg-fixed-voltage vdd-arm: Fixed regulator specified with variable voltages
[ 0.036612] reg-fixed-voltage: probe of vdd-arm failed with error -22
[ 0.037169] SCSI subsystem initialized
[ 0.037370] usbcore: registered new interface driver usbfs
[ 0.037414] usbcore: registered new interface driver hub
[ 0.037463] usbcore: registered new device driver usb
[ 0.037662] mc: Linux media interface: v0.10
[ 0.037700] videodev: Linux video capture interface: v2.00
[ 0.038704] Advanced Linux Sound Architecture Driver Initialized.
[ 0.039365] rockchip-cpuinfo cpuinfo: SoC : 0
[ 0.039384] rockchip-cpuinfo cpuinfo: Serial : 0000000000000000
[ 0.039716] rockchip,rknpor-powergood ff000000.syscon:rknpor-powergood: probe success!
[ 0.040471] clocksource: Switched to clocksource arch_sys_counter
[ 0.046113] NET: Registered protocol family 2
[ 0.046327] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.046774] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
Seeding 256 bits and crediting
[ 0.046807] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
Saving 256 bits of creditable seed for next boot
[ 0.046830] TCP bind hash table entries: 2048 (order: 1, 8192 bytes, linear)
Starting syslogd: [ 0.046852] TCP: Hash tables configured (established 2048 bind 2048)
OK
[ 0.046930] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
Starting klogd: OK
[ 0.046948] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.047064] NET: Registered protocol family 1
[ 0.047625] RPC: Registered named UNIX socket transport module.
Running sysctl: [ 0.047646] RPC: Registered udp transport module.
[ 0.047654] RPC: Registered tcp transport module.
[ 0.047660] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.050392] rockchip-thermal ff3c8000.tsadc: tsadc is probed successfully!
[ 0.051345] Initialise system trusted keyrings
[ 0.051567] workingset: timestamp_bits=30 max_order=16 bucket_order=0
[ 0.054909] squashfs: version 4.0 (2009/01/31) Phillip Lougher
OK
[ 0.055597] NFS: Registering the id_resolver key type
Populating /dev using udev: [ 0.055647] Key type id_resolver registered
[ 0.055656] Key type id_legacy registered
[ 0.055697] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.056144] Key type asymmetric registered
[ 0.056165] Asymmetric key parser 'x509' registered
[ 0.056188] io scheduler mq-deadline registered
[ 0.056526] rockchip-usb2phy ff3e0000.usb2-phy: IRQ index 0 not found
[ 0.060954] dma-pl330 ff420000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.060981] dma-pl330 ff420000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.061671] rockchip-pvtm ff240000.pvtm: pvtm@0 probed
[ 0.061814] rockchip-pvtm ff390000.pvtm: pvtm@0 probed
[ 0.062083] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.062564] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.067623] random: crng init done
[ 0.075236] brd: module loaded
[ 0.080111] loop: module loaded
[ 0.082023] spi-nand spi2.0: unknown raw ID 00000000
[ 0.082068] spi-nand: probe of spi2.0 failed with error -524
[ 0.082998] rk_gmac-dwmac ffa80000.ethernet: IRQ eth_lpi not found
[ 0.083151] rk_gmac-dwmac ffa80000.ethernet: PTP uses main clock
[ 0.083194] rk_gmac-dwmac ffa80000.ethernet: no regulator found
[ 0.083206] rk_gmac-dwmac ffa80000.ethernet: clock input or output? (input).
[ 0.083217] rk_gmac-dwmac ffa80000.ethernet: Can not read property: tx_delay.
[ 0.083226] rk_gmac-dwmac ffa80000.ethernet: set tx_delay to 0xffffffff
[ 0.083236] rk_gmac-dwmac ffa80000.ethernet: Can not read property: rx_delay.
[ 0.083243] rk_gmac-dwmac ffa80000.ethernet: set rx_delay to 0xffffffff
[ 0.083310] rk_gmac-dwmac ffa80000.ethernet: integrated PHY? (yes).
[ 0.083325] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_rx
[ 0.083334] rk_gmac-dwmac ffa80000.ethernet: cannot get clock mac_clk_tx
[ 0.083363] rk_gmac-dwmac ffa80000.ethernet: cannot get clock clk_mac_speed
[ 0.083372] rk_gmac-dwmac ffa80000.ethernet: clock input from PHY
[ 0.083617] rk_gmac-dwmac ffa80000.ethernet: init for RMII
[ 0.083801] rk_gmac-dwmac ffa80000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.083820] rk_gmac-dwmac ffa80000.ethernet: DWMAC4/5
[ 0.083834] rk_gmac-dwmac ffa80000.ethernet: DMA HW capability register supported
[ 0.083842] rk_gmac-dwmac ffa80000.ethernet: RX Checksum Offload Engine supported
[ 0.083849] rk_gmac-dwmac ffa80000.ethernet: TX Checksum insertion supported
[ 0.083857] rk_gmac-dwmac ffa80000.ethernet: Wake-Up On Lan supported
[ 0.083863] rk_gmac-dwmac ffa80000.ethernet: TSO supported
[ 0.083871] rk_gmac-dwmac ffa80000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.083879] rk_gmac-dwmac ffa80000.ethernet: TSO feature enabled
[ 0.083890] rk_gmac-dwmac ffa80000.ethernet: Using 40 bits DMA width
[ 0.090806] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.091116] usbcore: registered new interface driver usb-storage
[ 0.091257] gadgetfs: USB Gadget filesystem, version 24 Aug 2004
[ 0.091296] Mass Storage Function, version: 2009/09/11
[ 0.091310] LUN: removable file: (no medium)
[ 0.091336] no file given for LUN0
[ 0.091368] udc ffb00000.usb: failed to start g_mass_storage: -22
[ 0.092733] rockchip-rtc ff1c0000.rtc: registered as rtc0
[ 0.092809] rockchip-rtc ff1c0000.rtc: setting system clock to 2021-01-01T12:12:32 UTC (1609503152)
[ 0.093009] i2c /dev entries driver
[ 0.094708] usbcore: registered new interface driver uvcvideo
[ 0.094729] USB Video Class driver (1.1.1)
[ 0.095368] cpu cpu0: leakage=0
[ 0.095904] Synopsys Designware Multimedia Card Interface Driver
[ 0.096672] dtbocfg: 0.1.0
[ 0.096712] dtbocfg: OK
[ 0.097886] dwmmc_rockchip ffaa0000.mmc: No normal pinctrl state
[ 0.097909] dwmmc_rockchip ffaa0000.mmc: No idle pinctrl state
[ 0.098213] dwmmc_rockchip ffaa0000.mmc: is rv1106 sd
[ 0.098234] dwmmc_rockchip ffaa0000.mmc: IDMAC supports 32-bit address mode.
[ 0.098267] dwmmc_rockchip ffaa0000.mmc: Using internal DMA controller.
[ 0.098283] dwmmc_rockchip ffaa0000.mmc: Version ID is 270a
[ 0.098320] dwmmc_rockchip ffaa0000.mmc: DW MMC controller at irq 51,32 bit host data width,256 deep fifo
[ 0.099430] rv1106-acodec ff480000.acodec: current soc_id: rv1106
[ 0.099516] rv1106-acodec ff480000.acodec: Use pa_ctl_gpio and pa_ctl_delay_ms: 0
[ 0.101016] NET: Registered protocol family 17
[ 0.101115] Key type dns_resolver registered
[ 0.101928] Loading compiled-in X.509 certificates
[ 0.116229] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.127857] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 0.158925] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[ 0.159018] mmc1: new high speed SDHC card at address 0001
[ 0.159423] mmcblk1: mmc1:0001 EITSD 7.50 GiB
[ 0.159893] mmcblk1: p1(env) p2(idblock) p3(uboot) p4(boot) p5(oem) p6(userdata) p7(rootfs)
[ 0.213048] ALSA device list:
[ 0.213074] #0: rv-acodec
[ 0.222435] EXT4-fs (mmcblk1p7): INFO: recovery required on readonly filesystem
[ 0.222457] EXT4-fs (mmcblk1p7): write access will be enabled during recovery
[ 0.371443] EXT4-fs (mmcblk1p7): recovery complete
[ 0.381190] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
[ 0.381260] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 0.390325] devtmpfs: mounted
[ 0.390529] Freeing unused kernel memory: 196K
[ 0.390539] Kernel memory protection not selected by kernel config.
[ 0.390565] Run /sbin/init as init process
[ 0.397011] process '/bin/busybox' started with executable stack
[ 0.474162] EXT4-fs (mmcblk1p7): re-mounted. Opts: (null)
[ 0.673417] udevd[85]: starting version 3.2.7
[ 0.680046] udevd[85]: specified group 'input' unknown
[ 0.681399] udevd[85]: specified group 'kvm' unknown
[ 0.718178] udevd[86]: starting eudev-3.2.7
[ 1.602153] EXT4-fs (mmcblk1p6): recovery complete
[ 1.606665] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.606710] ext4 filesystem being mounted at /mnt/sdcard supports timestamps until 2038 (0x7fffffff)
[ 1.636174] EXT4-fs (mmcblk1p5): recovery complete
[ 1.639247] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
done
Unmounting : /dev/mmcblk1p5 (/mnt/sdcard)
Unmounting : /dev/mmcblk1p6 (/mnt/sdcard)
Unmounting : /dev/mmcblk1p7 (/mnt/sdcard)
Partition is not mounted: /dev/mmcblk1p8
/etc/init.d/S20linkmount: line 46: resize2fs: not found
/etc/init.d/S20linkmount: line 61: e2fsck: not found
[ 1.789368] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
/etc/init.d/S20linkmount: line 64: resize2fs: not found
[ 1.789417] ext4 filesystem being mounted at /userdata supports timestamps until 2038 (0x7fffffff)
/etc/init.d/S20linkmount: line 65: tune2fs: not found
[ 1.816155] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
Initializing random number generator... done.
Starting network: /dev/block/by-name/userdata on /userdata type ext4 (rw,relatime)
[ 1.936365] rk_dvbm ffa70000.rkdvbm: probe start
[ 1.936403] rk_dvbm ffa70000.rkdvbm: dvbm ctx cdb13263
[ 1.940966] rk_dvbm ffa70000.rkdvbm: probe success
[ 1.954514] imx219 4-0010: Driver IMX219 For Rockchip
OK
[ 1.954588] imx219 4-0010: supply VANA not found, using dummy regulator
Starting ntpd: [ 1.954807] imx219 4-0010: supply VDIG not found, using dummy regulator
[ 1.954864] imx219 4-0010: supply VDDL not found, using dummy regulator
[ 1.954965] imx219 power_on
[ 1.966574] imx219 4-0010: Detected imx0219 sensor
[ 1.967128] imx imx219_suspend
[ 1.967140] imx219 power off
[ 1.992024] rkcifhw ffa10000.rkcif: no iommu attached, using non-iommu buffers
[ 1.992046] rkcifhw ffa10000.rkcif: No reserved memory region assign to CIF
[ 1.992403] rkcif rkcif-mipi-lvds: rkcif driver version: v00.02.00
[ 1.992504] rkcif rkcif-mipi-lvds: attach to cif hw node
[ 1.992516] rkcif rkcif-mipi-lvds: failed to get dphy hw node
[ 1.992526] rkcif rkcif-mipi-lvds: rkcif wait line 0
[ 1.992534] rkcif rkcif-mipi-lvds: rkcif fastboot reserve bufs num 3
[ 1.992547] : terminal subdev does not exist
[ 1.992555] : terminal subdev does not exist
[ 1.992562] : terminal subdev does not exist
[ 1.992569] : terminal subdev does not exist
[ 1.992580] : get_remote_sensor: video pad[0] is null
[ 1.992589] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 1.992598] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 1.992606] : get_remote_sensor: video pad[0] is null
[ 1.992612] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 1.992620] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 1.992626] : get_remote_sensor: video pad[0] is null
[ 1.992633] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 1.992640] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 1.992647] : get_remote_sensor: video pad[0] is null
[ 1.992653] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 1.992661] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.000325] rkcif rkcif-mipi-lvds: No memory-region-thunderboot specified
[ 2.001455] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 2.001614] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 2.001745] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 2.001858] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 2.002203] rockchip-mipi-csi2 mipi0-csi2: attach to csi2 hw node
[ 2.002260] rkcif rkcif-mipi-lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 2.002276] rockchip-mipi-csi2: Async registered subdev
[ 2.002287] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds!
OK
[ 2.029881] rkisp_hw ffa00000.rkisp: is_thunderboot: 0
[ 2.029904] rkisp_hw ffa00000.rkisp: Missing rockchip,grf property
[ 2.029944] rkisp_hw ffa00000.rkisp: max input:0x0@0fps
[ 2.030099] rkisp_hw ffa00000.rkisp: get sram size:253952
[ 2.030112] rkisp_hw ffa00000.rkisp: no iommu attached, using non-iommu buffers
[ 2.030122] rkisp_hw ffa00000.rkisp: No reserved memory region. default cma area!
[ 2.030510] rkisp rkisp-vir0: rkisp driver version: v02.05.00
[ 2.030627] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 2.033159] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 2.048259] rockchip-csi2-dphy-hw ff3e8000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 2.062796] rockchip-csi2-dphy csi2-dphy0: dphy0 matches imx219 4-0010:bus type 5
[ 2.067053] rkcif-mipi-lvds: Async subdev notifier completed
[ 2.067081] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 2.069180] rkisp-vir0: Note: bayer raw need width 16 align, height 8 align!
[ 2.069180] suggest (104,368)/2960x1360, specical requirements, Ignore!
[ 2.069221] rkisp-vir0: Async subdev notifier completed
[ 2.296859] rkcif rkcif-mipi-lvds: clear unready subdev num: 0
[ 2.297073] rkisp rkisp-vir0: clear unready subdev num: 0
[ 2.313845] rga: rga2, irq = 37, match scheduler
[ 2.314546] rga: rga2 hardware loaded successfully, hw_version:3.3.87975.
[ 2.314570] rga: rga2 probe successfully
[ 2.314816] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[ 2.316266] rga: Module initialized. v1.3.1
[ 2.350183] mpp_vcodec: loading out-of-tree module taints kernel.
[ 2.364890] mpp_vcodec: init new
[ 2.365036] mpp_service mpp-srv: 424abb9b author: Yandong Lin 2024-04-29 [mpp_enc]: fix wrap enc sw timeout when resolution switch
Starting sshd: [ 2.365050] mpp_service mpp-srv: probe start
[ 2.366176] mpp_rkvenc_540c ffa50000.rkvenc: probing start
[ 2.366396] mpp_rkvenc_540c ffa50000.rkvenc: probing finish
[ 2.366780] mpp_vepu_pp ffa60000.rkvenc-pp: probe device
Input rkcif-mipi-lvds Format:SRGGB10_1X10 Size:2968x1360@15fps Offset(104,368)
[ 2.366870] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_a_pp is not found!
[ 2.366883] vepu_pp_init:526: No aclk reset resource define
[ 2.366892] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_h_pp is not found!
[ 2.366899] vepu_pp_init:529: No hclk reset resource define
[ 2.368070] mpp_vepu_pp ffa60000.rkvenc-pp: probing finish
[ 2.368297] mpp_service mpp-srv: probe success
[ 2.387532] RKNPU ff660000.npu: RKNPU: rknpu iommu device-tree entry not found!, using non-iommu mode
[ 2.387953] RKNPU ff660000.npu: RKNPU: Initialized RKNPU driver: v0.9.2 for 20230825
[ 2.388048] RKNPU ff660000.npu: dev_pm_opp_set_regulators: no regulator (rknpu) found: -19
[ 2.437394] rockit_load start
[ 2.451635] rockit_load end
[ 2.470936] rve: rve_irq, irq = 53, match scheduler
[ 2.472743] rve: Driver loaded successfully rve[2] ver:[2021]58.1a
[ 2.472763] rve: probe successfully
[ 2.473994] rve: Module initialized. v1.0.6
ln: /oem/usr/www/userdata: No such file or directory
insmod_ko.sh: line 88: /oem/usr/ko/insmod_wifi.sh: not found
ln: /oem/usr/www/usb0: No such file or directory
ln: /oem/usr/www/sdcard: No such file or directory
sh: ==: argument expected
BusyBox v1.36.1 (2025-01-01 09:47:51 +07) multi-call binary.
Usage: ifconfig [-a] [IFACE] [ADDRESS]
Configure a network interface
[add ADDRESS[/PREFIXLEN]]
[del ADDRESS[/PREFIXLEN]]
[[-]broadcast [ADDRESS]] [[-]pointopoint [ADDRESS]]
[netmask ADDRESS] [dstaddr ADDRESS]
[outfill NN] [keepalive NN]
[hw ether|infiniband ADDRESS] [metric NN] [mtu NN]
[[-]trailers] [[-]arp] [[-]allmulti]
[multicast] [[-]promisc] [txqueuelen NN] [[-]dynamic]
[mem_start NN] [io_addr NN] [irq NN]
[up|down] ...
Error: not found rkipc.ini !!!
/oem/usr/bin/RkLunch.sh: exit: line 111: Illegal number: -1
OK
Starting telnetd: OK
[ 2.724375] rk_gmac-dwmac ffa80000.ethernet eth0: PHY [stmmac-0:02] driver [RK630 PHY] (irq=POLL)
[ 2.725208] dwmac4: Master AXI performs any burst length
[ 2.725237] rk_gmac-dwmac ffa80000.ethernet eth0: No Safety Features support found
/etc/init.d/S50usbdevice: line 144: can't open : no such file
[ 2.725256] rk_gmac-dwmac ffa80000.ethernet eth0: PTP not supported by HW
Debug: configfs_init
[ 2.725554] rk_gmac-dwmac ffa80000.ethernet eth0: configuring for phy/rmii link mode
[ 2.741889] udevd[307]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video0': No such file or directory
[ 2.752103] udevd[309]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video2': No such file or directory
[ 2.762765] udevd[312]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video3': No such file or directory
[ 2.769867] udevd[314]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video4': No such file or directory
[ 2.777212] udevd[315]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video5': No such file or directory
[ 2.779766] udevd[316]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video6': No such file or directory
[ 2.788777] udevd[318]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video7': No such file or directory
[ 2.890401] file system registered
mkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
[ 2.968406] using random self ethernet address
[ 2.968430] using random host ethernet address
mkdir: can't create directory '/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6': No such file or directory
[ 3.015775] Mass Storage Function, version: 2009/09/11
[ 3.015802] LUN: removable file: (no medium)
[ 3.103143] read descriptors
[ 3.103214] read strings
[ 4.075417] usb0: HOST MAC 1e:81
[ 4.075440] usb0: MAC 72:1d:aa:7f:e0:2f
/usr/bin/luckfox-config: line 46: warning: command substitution: ignored null byte in input
[ 4.801010] RK630 PHY stmmac-0:02: failed to read out thermal zone (-11)
[ 5.310832] RK630 PHY stmmac-0:02: failed to read out thermal zone (-11)
[ 5.820800] RK630 PHY stmmac-0:02: failed to read out thermal zone (-11)
Only Luckfox Pico Ultra /Luckfox Pico Ultra W support RGB
Complete configuration loading
/root/main.py and /root/boot.py not exist ,pass...
OK
RTC does not require time calibration
current_ip = 172.32.0.70
TARGET_IP = 172.32.0.93
[ 6.880946] RK630 PHY stmmac-0:02: failed to read out thermal zone (-11)
luckfox : set usb0 ip
172.32.0.93
usb0 config success
