LF Pico Plus - MobaXterm - Network error: Connection refused.
Posted: 2025-01-20 5:06
I recently got this and was following the guide https://wiki.luckfox.com/Luckfox-Pico/L ... co-prepare and made it to flashing the device to SSH/Telnet Login. I have tried the 172.32.0.100 port 22 configuration (Network error: Connection refused). Windows 11 - cmd > ipconfig/all Ethernet adapter Ethernet 4 - remote NDIS based Internet Sharing Device.
IPv4 Address 172.32.0.100 showing. Public/Private firewall are disabled for the testing.
Allowed the autoconfiguration to take effect and ran ipconfig/all again and the device shows another IP address, and again MobaXterm is not connecting. I am currently SPI-nand flashed using firmware>buildroot>Luckfox_Pico_Plus_Flash.zip (plus_buildroot_spinand).
Device is currently connected via USB-C & Ethernet cable to the back of the PC motherboard directly. Rockchip SOC toolkit doesn't fail out. Red LED near the USB port flashes like a boot sequence.
I am at a loss as to what is happening. I was hoping to use the RESTOUCH image for a resistive touchscreen, but I am unable to get past the SSH/Telnet login section to start using this device more.
