hello, I want to use mini B as a locator for my car,Can I use a GPS module on luckfox pico mini B?
i have some module gps (quectel L96 ,DW1000)
gps module on mini B
We have not tested the use of GPS modules on the LuckFox Pico Mini B, so the following are suggestions for your reference. For the Quectel L96, it supports data transmission through a UART interface. You will need to obtain the official datasheet to communicate with it properly. As for the DW1000, it supports communication via an SPI interface, and you would need to understand the format for SPI interaction to communicate with this module. The LuckFox Pico Mini B does have the relevant interfaces, so theoretically, it should be possible to use GPS modules with it.
