Disable automatic white balance/exposure/gamma correction sc3336
Hello. How is it possible to disable automatic white balance/exposure/gamma correction on luckfox pico pro + sc3336? And how is it possible to manually adjust these parameters? When working with opencv-mobile, an automatic sudden change in white balance spoils all the configured work.
Hello, opencv-mobile actually calls the interface of rkaiq when calling the camera, rkaiq is dependent on the iqfiles of the camera to run, if you need to modify white balance/exposure/gamma and other values, you need to modify iqfiles, this part belongs to the isp tuning content, we have no relevant experience.
In other ISP modules that ensure that the camera works properly, there are settings that rely on white balance/exposure/gamma, and it is not recommended to modify the iqfiles as if the modification of the parameters will affect the final running effect
