Hi team,
I am trying to do ISP tuning with my Pico Max IPC.
When I run rkaiq_tool_server on my Pico Max Linux system, it reports
[aiqtool][Setup]:connect domain server failed. Error
[aiqtool][main]:#### ToolServer connect AIQ failed ####
Is there anything wrong there and how can I fix the errors? Can the errors be ignored and continue my ISP tuning?
The full log as below:
[root@luckfox ]# rkaiq_tool_server
[aiqtool][main]:#### 2023-7-31 11:17:41 ####
[aiqtool][main]:iqfile cmd_parser.get /oem/etc/iqfiles
[aiqtool][main]:g_mode cmd_parser.get -1
[aiqtool][main]:g_width cmd_parser.get 1920
[aiqtool][main]:g_height cmd_parser.get 1080
[aiqtool][main]:g_device_id cmd_parser.get 0
[aiqtool][GetMediaInfo]:access /dev/media0
[aiqtool][GetCifSubDevs]:cif media index 0, media info array id 0
[aiqtool][GetLensSubDevs]:isp media index 0, media info array id 0
[aiqtool][GetMediaInfo]:access /dev/media1
[aiqtool][GetIspSubDevs]:isp media index 1, media info array id 0
[aiqtool][GetIspSubDevs]:model(rkisp0): isp_info(0): isp-subdev entity name: /dev/v4l-subdev3
[aiqtool][DumpMediaInfo]:DumpMediaInfo:
[aiqtool][DumpMediaInfo]: sensor_name : m00_f_imx307 4-001a
[aiqtool][DumpMediaInfo]:#### cif:
[aiqtool][DumpMediaInfo]: model_idx : 0
[aiqtool][DumpMediaInfo]: linked_sensor : 1
[aiqtool][DumpMediaInfo]: media_dev_path : /dev/media0
[aiqtool][DumpMediaInfo]: mipi_id0 : /dev/video0
[aiqtool][DumpMediaInfo]: mipi_id1 : /dev/video1
[aiqtool][DumpMediaInfo]: mipi_id2 : /dev/video2
[aiqtool][DumpMediaInfo]: mipi_id3 : /dev/video3
[aiqtool][DumpMediaInfo]: rkcif_tools_id0 : /dev/video10
[aiqtool][DumpMediaInfo]: mipi_dphy_rx_path :
[aiqtool][DumpMediaInfo]: mipi_csi2_sd_path : /dev/v4l-subdev0
[aiqtool][DumpMediaInfo]: lvds_sd_path :
[aiqtool][DumpMediaInfo]: mipi_luma_path :
[aiqtool][DumpMediaInfo]:#### isp:
[aiqtool][DumpMediaInfo]: model_idx : 1
[aiqtool][DumpMediaInfo]: linked_sensor : 0
[aiqtool][DumpMediaInfo]: media_dev_path : /dev/media1
[aiqtool][DumpMediaInfo]: isp_dev_path : /dev/v4l-subdev3
[aiqtool][DumpMediaInfo]: csi_dev_path :
[aiqtool][DumpMediaInfo]: mpfbc_dev_path :
[aiqtool][DumpMediaInfo]: main_path : /dev/video11
[aiqtool][DumpMediaInfo]: self_path : /dev/video12
[aiqtool][DumpMediaInfo]: fbc_path :
[aiqtool][DumpMediaInfo]: rawwr0_path :
[aiqtool][DumpMediaInfo]: rawwr1_path :
[aiqtool][DumpMediaInfo]: rawwr2_path :
[aiqtool][DumpMediaInfo]: rawwr3_path :
[aiqtool][DumpMediaInfo]: dma_path :
[aiqtool][DumpMediaInfo]: rawrd0_m_path : /dev/video17
[aiqtool][DumpMediaInfo]: rawrd1_l_path :
[aiqtool][DumpMediaInfo]: rawrd2_s_path : /dev/video18
[aiqtool][DumpMediaInfo]: stats_path : /dev/video19
[aiqtool][DumpMediaInfo]: input_params_path : /dev/video20
[aiqtool][main]:================== -1 =====================
[aiqtool][Setup]:Linux,Create domain socket success.
[aiqtool][Process]:TCPServer::Process
[aiqtool][Accepted]:TCPServer::Accepted
rkaiq_tool_server reports "connect AIQ failed"
Hello, rkisp tuning is not for individual users, rkaiq_tool_server use needs to be used with rkisp_tuner on the PC, please consult Rockchip official if necessary, we do not have the relevant sharing permission
This issue has been resolved by running rkaiq_3A_server before rkaiq_tool_server.
Hi Keens, Can you please let me know from where you downloaded the RKISP TOOLS and go about connecting?
