Luckfox pico max board with imx307 camera
When runing rkaiq_3A_server and rkaiq_tool_server, it shows:
[aiqtool][DumpMediaInfo]:#### isp:
[aiqtool][DumpMediaInfo]: model_idx : 1
[aiqtool][DumpMediaInfo]: linked_sensor : 0
linked_sensor is 0, is this correct?
[root@luckfox root]# rkaiq_tool_server -d 0
[aiqtool][main]:#### 2023-7-31 11:17:41 ####
[aiqtool][main]:iqfile cmd_parser.get /oem/etc/iqfiles
[aiqtool][main]:g_mode cmd_parser.get -1
[aiqtool][main]:g_width cmd_parser.get 1920
[aiqtool][main]:g_height cmd_parser.get 1080
[aiqtool][main]:g_device_id cmd_parser.get 0
[aiqtool][GetMediaInfo]:access /dev/media0
[aiqtool][GetCifSubDevs]:cif media index 0, media info array id 0
[aiqtool][GetLensSubDevs]:isp media index 0, media info array id 0
[aiqtool][GetMediaInfo]:access /dev/media1
[aiqtool][GetIspSubDevs]:isp media index 1, media info array id 0
[aiqtool][GetIspSubDevs]:model(rkisp0): isp_info(0): isp-subdev entity name: /dev/v4l-subdev3
[aiqtool][DumpMediaInfo]:DumpMediaInfo:
[aiqtool][DumpMediaInfo]: sensor_name : m00_f_imx307 4-001a
[aiqtool][DumpMediaInfo]:#### cif:
[aiqtool][DumpMediaInfo]: model_idx : 0
[aiqtool][DumpMediaInfo]: linked_sensor : 1
[aiqtool][DumpMediaInfo]: media_dev_path : /dev/media0
[aiqtool][DumpMediaInfo]: mipi_id0 : /dev/video0
[aiqtool][DumpMediaInfo]: mipi_id1 : /dev/video1
[aiqtool][DumpMediaInfo]: mipi_id2 : /dev/video2
[aiqtool][DumpMediaInfo]: mipi_id3 : /dev/video3
[aiqtool][DumpMediaInfo]: rkcif_tools_id0 : /dev/video10
[aiqtool][DumpMediaInfo]: mipi_dphy_rx_path :
[aiqtool][DumpMediaInfo]: mipi_csi2_sd_path : /dev/v4l-subdev0
[aiqtool][DumpMediaInfo]: lvds_sd_path :
[aiqtool][DumpMediaInfo]: mipi_luma_path :
[aiqtool][DumpMediaInfo]: media_dev_path : /dev/media1
[aiqtool][DumpMediaInfo]: isp_dev_path : /dev/v4l-subdev3
[aiqtool][DumpMediaInfo]: csi_dev_path :
[aiqtool][DumpMediaInfo]: mpfbc_dev_path :
[aiqtool][DumpMediaInfo]: main_path : /dev/video11
[aiqtool][DumpMediaInfo]: self_path : /dev/video12
[aiqtool][DumpMediaInfo]: fbc_path :
[aiqtool][DumpMediaInfo]: rawwr0_path :
[aiqtool][DumpMediaInfo]: rawwr1_path :
[aiqtool][DumpMediaInfo]: rawwr2_path :
[aiqtool][DumpMediaInfo]: rawwr3_path :
[aiqtool][DumpMediaInfo]: dma_path :
[aiqtool][DumpMediaInfo]: rawrd0_m_path : /dev/video17
[aiqtool][DumpMediaInfo]: rawrd1_l_path :
[aiqtool][DumpMediaInfo]: rawrd2_s_path : /dev/video18
[aiqtool][DumpMediaInfo]: stats_path : /dev/video19
[aiqtool][DumpMediaInfo]: input_params_path : /dev/video20
[aiqtool][main]:================== -1 =====================
[aiqtool][Setup]:Linux,Create domain socket success.
[aiqtool][Setup]:Credentials from SO_PEERCRED: pid=1913, euid=0, egid=0
[aiqtool][main]:#### ToolServer connect AIQ success ####
[aiqtool][Process]:TCPServer::Process
[aiqtool][Accepted]:TCPServer::Accepted
rkaiq_tool_server启动时报isp linked_sensor为0,是否正确,是否影响后续的ISP tuning
Hello, we have no experience in ISP tuning, if you can get the RAW map on the tuner software, it should be possible to carry out subsequent ISP tuning, for a more accurate conclusion, please consult Rockchip official, ISP tuning is a commercial business provided by Rockchip, we are not able to provide, thank you for your understanding
