Hello, can you check if there are any pin reuse conflicts? May I ask if you are using Ubuntu or buildroot system?
Thank you Ryand,
I'm using buildroot:
[root@luckfox ]# cat /etc/os-release
NAME=Buildroot
VERSION=-g6a7f87806-dirty
ID=buildroot
VERSION_ID=2023.02.6
PRETTY_NAME="Buildroot 2023.02.6"
I'm not sure how to check for pin conflicts, but PWM pins are disabled:
[root@luckfox ]# luckfox-config show
/usr/bin/luckfox-config: line 46: warning: command substitution: ignored null byte in input
Luckfox_Pico_MiniA/B
+ -USB- +
- - VBUS | | 1V8 - -
- - GND | | GND - -
- - 3V3 | | GPIO4_C1 - SARADC_M1 -
- FIQtty_TX - GPIO1_B2 | | GPIO4_C0 - SARADC_M0 -
- FIQtty_RX - GPIO1_B3 | | GPIO0_A4 - - PWM1_M0
PWM2_M2 - SPI0_M0_CS0 - GPIO1_C0 | | GPIO1_C7 - - PWM11_M1
PWM4_M2 - SPI0_M0_CLK - GPIO1_C1 | | GPIO1_C6 - - PWM10_M1
PWM5_M2 - SPI0_M0_MOSI - GPIO1_C2 | | GPIO1_D3 - - PWM11_M2
PWM6_M2 - SPI0_M0_MISO - GPIO1_C3 | | GPIO1_D2 - - PWM0_M1
PWM8_M1 - UART4_M1_RX - GPIO1_C4 | | GPIO1_D1 - UART3_M1_RX - PWM10_M2
PWM9_M1 - UART4_M1_TX - GPIO1_C5 | | GPIO1_D0 - UART3_M1_TX - PWM3_M2
Forgot to mention that right after entering I2C menu I get this message: "No I2C Pins".
Thank you, that worked!
Another question, I'm trying to connect an I2C device that is master, is there are way to set Pico Mini buildroot as slave? When I send I2C data from the attached device the address isn't found, meaning Pico Mini should define its slave address first. But I couldn't find a way to set the slave address in the sample program:
https://drive.google.com/drive/folders/ ... drive_link
The i2c controller of rv1106 does not support slave mode. To implement it, only gpio can simulate i2c, and the driver may need to be modified. If there are no special requirements, it is recommended to use SPI. The SPI controller of rv1106 supports both master and slave modes.
I want to detect I2C pins level changes, could you please provide an example or direct me to documentation for the RV1103 with Buildroot on how to set GPIO interrupts?
Hello, to test the I2C pin level changes, you can use the command set from i2c-tools to assist with testing. For related I2C documentation, please refer to
https://wiki.luckfox.com/zh/Luckfox-Pic ... x-Pico-I2C. We do not have examples or documentation for detecting I2C pin level changes through GPIO interrupts. If needed, you can refer to relevant blogs and tutorials. Most Cortex-A platforms use a similar approach for controlling I2C at the application layer.
