// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
* Copyright (c) 2022 Rockchip Electronics Co., Ltd.
/dts-v1/;
#include "rv1106.dtsi"
#include "rv1106-luckfox-pico-ultra-ipc.dtsi"
#include <dt-bindings/input/input.h>
#include <dt-bindings/display/media-bus-format.h>
model = "Luckfox Pico Ultra W";
compatible = "rockchip,rv1103g-38x38-ipc-v10", "rockchip,rv1106g3";
restart-poweroff {
compatible = "restart-poweroff";
sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
pinctrl-names = "default";
reset-gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_LOW>;
wireless_bluetooth: wireless-bluetooth {
compatible = "bluetooth-platdata";
uart_rts_gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
pinctrl-names = "default", "rts_gpio";
pinctrl-0 = <&uart1m0_rtsn>;
pinctrl-1 = <&uart1_gpios>;
BT,wake_gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
BT,wake_host_irq = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>;
/**********CRU**********/
//&cru {
// assigned-clocks =
// <&cru PLL_GPLL>, <&cru PLL_CPLL>,
// <&cru ARMCLK>,
// <&cru ACLK_PERI_ROOT>, <&cru HCLK_PERI_ROOT>,
// <&cru PCLK_PERI_ROOT>, <&cru ACLK_BUS_ROOT>,
// <&cru PCLK_TOP_ROOT>, <&cru PCLK_PMU_ROOT>,
// <&cru HCLK_PMU_ROOT>, <&cru CLK_500M_SRC>;
// assigned-clock-rates =
// <1188000000>, <700000000>,
// <1104000000>,
// <400000000>, <200000000>,
// <100000000>, <300000000>,
// <100000000>, <100000000>,
// <200000000>, <700000000>;
/**********NPU**********/
//&npu {
// assigned-clock-rates = <700000000>;
/**********EMMC**********/
&emmc {
bus-width = <8>;
cap-mmc-highspeed;
non-removable;
// mmc-hs200-1_8v;
rockchip,default-sample-phase = <90>;
no-sdio;
no-sd;
memory-region-ecsd = <&mmc_ecsd>;
post-power-on-delay-ms = <0>;
&fiq_debugger {
rockchip,irq-mode-enable = <1>;
/**********SDIO-WIFI**********/
&sdmmc {
max-frequency = <50000000>;
bus-width = <4>;
cap-sd-highspeed;
cap-sdio-irq;
keep-power-in-suspend;
non-removable;
// no-sd;
// no-mmc;
supports-sdio;
mmc-pwrseq = <&sdio_pwrseq>;
pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>;
&pinctrl{
sdmmc0{
sdmmc0_det: sdmmc0-det {
rockchip,pins =
/* sdmmc0_det */
<3 RK_PA1 1 &pcfg_pull_down>;
/***********I2C2**********/
&panel {
status = "disabled";
&rgb {
&rgb_in_vop {
&route_rgb {
&vop {
/**********I2C**********/
&i2c2 {
status="okay";
clock-frequency=<400000>;
pinctrl-names="default";
pinctrl-0=<&i2c2m0_xfer>;
/**********ETH**********/
&gmac {
/**********USB**********/
&usbdrd_dwc3 {
#dr_mode = "peripheral";
dr_mode = "host";
/**********RTC**********/
&rtc {
/**********BT**********/
&uart1 {
pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn>;
&pinctrl {
uart1_gpios: uart1-gpios {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
/**********SPI**********/
&spi0 {
spidev@0 {
spi-max-frequency = <50000000>;
/**********UART5**********/
&uart5 {
pinctrl-0 = <&uart5m1_xfer>;
&uart2 { status = "okay";
pinctrl-0 = <&uart2m0_xfer>;
gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-0 = <&pwr_key>;
power-key {
gpios = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>;
linux,code = <KEY_POWER>;
label ="GPIO Key Power";
debounce-interval = <100>;
wakeup-source;
&pinctrl {
buttons {
pwr_key:pwr-key{
rockchip,pins = <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
