When usb camera is attached, and relevant modules are loaded no video source is detected. However I can see the usb device in LSUSB stdout.
[root@luckfox root]# insmod /oem/usr/ko/gspca_main.ko
[root@luckfox root]# insmod /oem/usr/ko/gspca_ov534.ko
[root@luckfox root]# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 003: ID 1415:2000
Bus 002 Device 001: ID 1d6b:0003
[root@luckfox root]# v4l2-ctl --list-devices
rkisp-statistics (platform: rkisp):
/dev/video19
/dev/video20
rkcif-mipi-lvds (platform:rkcif):
/dev/media0
rkisp_mainpath (platform:rkisp-vir0):
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video17
/dev/video18
/dev/media1
Failed to open /dev/video0: No such device
USB Camera-B4.09.24.1 (usb-xhci-hcd.0.auto-1):
/dev/video21
ffmpeg throws same info on STDOUT, at the same time kernel messages also indicate frame overflow (ov534 1-1:1.0: frame overflow 614872 > 614400).
frame= 355 fps= 26 q=29.0 size= 675kB time=00:00:13.30 bitrate= 415.5kbits/s s
frame= 370 fps= 26 q=23.1 size= 693kB time=00:00:13.80 bitrate= 411.5kbits/s s
frame= 386 fps= 27 q=16.0 size= 721kB time=00:00:14.33 bitrate= 411.9kbits/s s
frame= 400 fps= 27 q=23.7 size= 738kB time=00:00:14.80 bitrate= 408.4kbits/s s
frame= 416 fps= 27 q=23.2 size= 757kB time=00:00:15.33 bitrate= 404.2kbits/s s
frame= 431 fps= 27 q=25.4 size= 775kB time=00:00:15.86 bitrate= 399.9kbits/s s
frame= 447 fps= 27 q=31.0 size= 803kB time=00:00:16.40 bitrate= 401.0kbits/s s
frame= 462 fps= 27 q=28.7 size= 821kB time=00:00:16.90 bitrate= 397.8kbits/s s
frame= 478 fps= 27 q=29.4 size= 839kB time=00:00:17.43 bitrate= 394.3kbits/s s
frame= 494 fps= 27 q=21.4 size= 865kB time=00:00:17.96 bitrate= 394.4kbits/s s
frame= 508 fps= 27 q=25.8 size= 881kB time=00:00:18.46 bitrate= 391.0kbits/s s
frame= 524 fps= 27 q=26.3 size= 899kB time=00:00:19.00 bitrate= 387.4kbits/s s
frame= 537 fps= 27 q=26.1 size= 914kB time=00:00:19.43 bitrate= 385.2kbits/s s
[video4linux2,v4l2 @ 0x556960] Dequeued v4l2 buffer contains 2064 bytes, but 614400 were expected. Flags: 0x00002001.
[video4linux2,v4l2 @ 0x556960] Dequeued v4l2 buffer contains 2072 bytes, but 614400 were expected. Flags: 0x00002001.
[root@luckfox root]# v4l2-ctl --device=/dev/video21 --all
Driver Info:
Driver name : ov534
Card type : USB Camera-B4.09.24.1
Bus info : usb-xhci-hcd.0.auto-1
Driver version : 5.10.160
Capabilities : 0x85200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x05200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (ov534: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'YUYV' (YUYV 4:2:2)
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Limited Range)
Flags :
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 2
User Controls
brightness 0x00980900 (int) : min=0 max=255 step=1 default=0 value=0 flags=slider
contrast 0x00980901 (int) : min=0 max=255 step=1 default=32 value=32 flags=slider
saturation 0x00980902 (int) : min=0 max=255 step=1 default=64 value=64 flags=slider
hue 0x00980903 (int) : min=-90 max=90 step=1 default=0 value=0 flags=slider
white_balance_automatic 0x0098090c (bool) : default=1 value=1
exposure 0x00980911 (int) : min=0 max=255 step=1 default=120 value=120 flags=inactive, volatile
gain_automatic 0x00980912 (bool) : default=1 value=1 flags=update
gain 0x00980913 (int) : min=0 max=63 step=1 default=20 value=20 flags=inactive, volatile
horizontal_flip 0x00980914 (bool) : default=0 value=0
vertical_flip 0x00980915 (bool) : default=0 value=0
power_line_frequency 0x00980918 (menu) : min=0 max=1 default=0 value=0 (Disabled)
0: Disabled
1: 50 Hz
sharpness 0x0098091b (int) : min=0 max=63 step=1 default=0 value=0 flags=slider
Camera Controls
auto_exposure 0x009a0901 (menu) : min=0 max=1 default=0 value=0 (Auto Mode) flags=update
0: Auto Mode
1: Manual Mode
[root@luckfox root]# v4l2-ctl -d 21 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'GRBG' (8-bit Bayer GRGR/BGBG)
Interval: Discrete 0.005s (187.000 fps)
Interval: Discrete 0.007s (150.000 fps)
Interval: Discrete 0.007s (137.000 fps)
Interval: Discrete 0.008s (125.000 fps)
Interval: Discrete 0.010s (100.000 fps)
Interval: Discrete 0.013s (75.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.020s (50.000 fps)
Interval: Discrete 0.027s (37.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.025s (40.000 fps)
Interval: Discrete 0.067s (15.000 fps)
[1]: 'YUYV' (YUYV 4:2:2)
