Welcome to luckfox pico
luckfox login: root
Password:
[root@luckfox root]# pip
Error processing line 1 of /usr/lib/python3.11/site-packages/distutils-precedence.pth:
Fatal Python error: init_import_site: Failed to import the site module
Python runtime state: initialized
Traceback (most recent call last):
File "<frozen site>", line 186, in addpackage
File "<string>", line 1, in <module>
ImportError: bad magic number in '_distutils_hack': b''
During handling of the above exception, another exception occurred:
File "<frozen site>", line 616, in <module>
File "<frozen site>", line 603, in main
File "<frozen site>", line 384, in addsitepackages
File "<frozen site>", line 226, in addsitedir
File "<frozen site>", line 196, in addpackage
ImportError: bad magic number in 'traceback': b''
[root@luckfox root]# pip install opencv-python -i https://pypi.tuna.tsinghua.edu
.cn/simple
[root@luckfox root]# yum remove python3.11
-sh: yum: not found
[root@luckfox root]# find / -name "*.pyc" -delete
find: unrecognized: -delete▒
BusyBox v1.36.1 (2025-03-21 20:42:21 CST) multi-call binary.
Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS]
Search for files and perform actions on them.
First failed action stops processing of current file.
Defaults: PATH is current directory, action is '-print'
-L,-follow Follow symlinks
-H ...on command line only
-xdev Don't descend directories on other filesystems
-maxdepth N Descend at most N levels. -maxdepth 0 applies
actions to command line arguments only
-mindepth N Don't act on first N levels
-depth Act on directory *after* traversing it
Actions:
( ACTIONS ) Group actions for -o / -a
! ACT Invert ACT's success/failure
ACT1 [-a] ACT2 If ACT1 fails, stop, else do ACT2
ACT1 -o ACT2 If ACT1 succeeds, stop, else do ACT2
Note: -a has higher priority than -o
-name PATTERN Match file name (w/o directory name) to PATTERN
-iname PATTERN Case insensitive -name
-path PATTERN Match path to PATTERN
-ipath PATTERN Case insensitive -path
-regex PATTERN Match path to regex PATTERN
-type X File type is X (one of: f,d,l,b,c,s,p)
-executable File is executable
-perm MASK At least one mask bit (+MASK), all bits (-MASK),
or exactly MASK bits are set in file's mode
-mtime DAYS mtime is greater than (+N), less than (-N),
or exactly N days in the past
-atime DAYS atime +N/-N/N days in the past
-ctime DAYS ctime +N/-N/N days in the past
-mmin MINS mtime is greater than (+N), less than (-N),
or exactly N minutes in the past
-amin MINS atime +N/-N/N minutes in the past
-cmin MINS ctime +N/-N/N minutes in the past
-newer FILE mtime is more recent than FILE's
-samefile FILE File is same as FILE
-user NAME/ID File is owned by given user
-group NAME/ID File is owned by given group
-size N[bck] File size is N (c:bytes,k:kbytes,b:512 bytes(def.))
+/-N: file size is bigger/smaller than N
-empty Match empty file/directory
-prune If current file is directory, don't descend into it
If none of the following actions is specified, -print is assumed
-print Print file name
-print0 Print file name, NUL terminated
-exec CMD ARG ; Run CMD with all instances of {} replaced by
file name. Fails if CMD exits with nonzero
-exec CMD ARG + Run CMD with {} replaced by list of file names
-quit Exit
.cn/simple
[root@luckfox root]# ls
[root@luckfox root]# ls -a
[root@luckfox root]# python3
[root@luckfox root]# python3 -m compileall /usr/lib/python3.11
