Hello
Does usb wifi/bluetooth works on Luckfox pico mini A?
(i am just curious
before i buy the usb
Hello, most of the USB Wi-Fi/BT is common to multiple platforms, in the driver Luckfox Pico Mini A theoretically supports, you need to open the corresponding kernel settings according to the selected Wi-Fi/BT module.
In terms of hardware, the Luckfox pico mini A only has one USB port, if it is used to connect to USB Wi-Fi/BT, you need to consider powering the Luckfox pico mini A from the VBUS pin or choosing a USB docking station with power supply
