Problem with Luckfox Pico Plus Not Detecting SD Card in Soctoolkit
  • The Windows Software doesn't seem to work anymore in general:
    https://spotpear.com/LuckFox-Pico-Linux ... r/119.html
    And as it seems here support seems to be officially abandoned. The Wiki still references it along with the no longer existing Ubuntu images.
  • The only way I get it to show the SD card is by formatting it manually. Which has to be done for each session.
    But I never got it to boot. So this might only partially skip the symptoms of the issue.
    edit:
    Correction, does no longer work.
  • SocToolKit is provided by Rockchip. Currently, we do not have an updated version. Personally, during my use, I found that the SD card could only be recognized after the software was turned on. Otherwise, there would often be situations where the computer recognized it but the software did not.
