I am evaluating yolov5 rknn sample. I've installed SDK and completed conversion of onyx->rknn. Development pc is connected to the board via add interface, and boards can reply pings.
I have transferred rknn server files to the board via add push:
[root@luckfox root]# strings /oem/usr/bin/rknn_server | grep -i "rknn_server version"
rknn_server version: 2.3.0 (e80ac5c build@2024-11-07T12:53:13)
[root@luckfox root]# strings /oem/usr/lib/librknnmrt.so | grep -i "librknnmrt version"
librknnmrt version: 2.3.0 (c949ad889d@2024-11-07T11:37:43)
(venv) luckfox@luckfox:~/rknn_model_zoo/examples/yolov5/python$ python ./yolov5.py --model_path ../model/yolov5s_relu.rknn --target rv1106 --img_show
use anchors from '../model/anchors_yolov5.txt', which is [[[10.0, 13.0], [16.0, 30.0], [33.0, 23.0]], [[30.0, 61.0], [62.0, 45.0], [59.0, 119.0]], [[116.0, 90.0], [156.0, 198.0], [373.0, 326.0]]]
I rknn-toolkit2 version: 2.3.0
--> Init runtime environment
adb: unable to connect for root: closed
I target set by user is: rv1106
I Get hardware info: target_platform = rv1103, os = Linux, aarch = aarch32
I Check RV1106 board npu runtime version
E init_runtime: get target_platform is rv1106, while required target_platform = rv1103
d, please use /proc/2117/oom_score_adj instead."
How can I troubleshoot the adb connection error and the inaccurate target platform identification?
Kind regards,
