modetest :failed to set gamma: Invalid argument
Posted: 2025-03-21 3:48
您好!我用外购的SPI+RGB屏,在移植LuckFox Pico Ultra的程序后,执行modetest命令,出现 :failed to set gamma: Invalid argument,请问哪里存在问题。
http://forums.luckfox.com/
modetest -s <connector_id>@<crtc_id>:<mode>Code: Select all
&display {
gamma = <0>;
};Code: Select all
// drm_display.c
// 注释掉Gamma校正相关代码
// drm_mode_gamma_set(crtc, gamma_lut);用modetest的方法,出现:pimouren wrote: ↑2025-03-21 8:36 你好,可以在使用modetest命令时,避免使用Gamma校正相关的选项。例如:也可以更改设备树:Code: Select all
modetest -s <connector_id>@<crtc_id>:<mode>或者修改驱动代码Code: Select all
&display { gamma = <0>; };Code: Select all
// drm_display.c // 注释掉Gamma校正相关代码 // drm_mode_gamma_set(crtc, gamma_lut);
