tracking model
Posted: 2025-03-24 7:58
by mchertz
is it possible to implement any tracking model on Luckfox Pico Max RV1106? for this it is necessary to deploy the "ultralytics" package on the board? or is it possible to get by with using "rknn"?
Re: tracking model
Posted: 2025-03-24 10:24
Hello, rv1106 has limited CPU performance, and it may not be ideal to run the "ultralytics" package directly with the cpu; If you use rknn, you need to choose a suitable model, and you may need to consider using a custom operator if the operators are incompatible, which requires a high degree of familiarity with the model
Other customers have tried this before, you can refer to
viewtopic.php?p=1197&hilit=%E8%BF%BD%E8%B8%AA#p1197, we have limited knowledge of tracking models
