ArcFace RKNN Conversion Failure: Output is Always Zero on RV1106
  • Hello, porting a model to RKNN is a complex process that requires a solid understanding of the model itself. We do not have the capacity or resources to reproduce your testing environment, even though you have provided detailed information.
    In our experience, there are two common reasons why the model outputs all zeros:
    The input image format is incorrect (for example, the model expects BGR but receives RGB).
    The model conversion process was not properly configured, particularly the rknn.config parameters such as optimization_level and quantized_algorithm.
