Sleep mode
Posted: 2025-04-28 13:16
by luckfox_prototyper
Hi everyone.
Has anyone been able to put the luckfox pico ultra W into the sleep mode to consume less power? I've found PMU_PWR_CON register in RV1106 documentation, but I'm unable to write to it and I get segmentation fault everytime.
If anyone could share an example code how to put the board to low-power mode I'd be very grateful!
Re: Sleep mode
Posted: 2025-04-29 1:14
Hello, sleep-related operations can be referred to viewtopic.php?t=1395&hilit=%E4%BC%91%E7%9C%A0, direct operation of registers to control the PMU should not be able to achieve sleep wake-up, the state before the system sleep is not saved, which may cause the wake-up failure
Re: Sleep mode
Posted: 2025-04-29 23:30
Thank you for the reply.
I've now been able to put my RV1106 to sleep following that forum.
However the board won't wake when I connect the GND and the GPIO1_A0 pin. I've appended the following to my .dts file:
	gpio-keys {
		compatible = "gpio-keys";
		autorepeat;
		pinctrl-names = "default";
		pinctrl-0 = <&pwr_key>;
		power-key {
			gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
			linux,code = <KEY_POWER>;
			label ="GPIO Key Power";
			debounce-interval = <100>;
			wakeup-source;
&pinctrl {
	buttons {
		pwr_key:pwr-key{
			rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
I've had to reset the board to gain access to it, but that is not a viable solution to my problem.
I've been stuck on this step for way too long now. Do you maybe see anything that could be problematic?
Re: Sleep mode
Posted: 2025-04-30 1:19
There is no issue with your device tree configuration. Please check whether GPIO1 PA0 has been multiplexed for another function. Also, check the corresponding nodes under /proc/device-tree to see if they have been successfully registered.
