I've loaded many drivers into kernel that should now enable me to see the usb from core:
CONFIG_PPP=y
CONFIG_PPPOE=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_USB_USBNET=y
CONFIG_USB_NET_RNDIS_HOST=y
CONFIG_USB_ACM=y
CONFIG_USB_SERIAL=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_QUALCOMM=y
CONFIG_USB_SERIAL_OPTION=y
[ 1.003547] udevd[97]: specified group 'input' unknown
[ 1.004504] udevd[97]: specified group 'kvm' unknown
[ 1.026304] udevd[98]: starting eudev-3.2.7
[ 2.165207] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.165262] ext4 filesystem being mounted at /userdata supports timestamps until 2038 (0x7fffffff)
[ 2.318741] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.558590] rk_dvbm ffa70000.rkdvbm: probe start
[ 2.558628] rk_dvbm ffa70000.rkdvbm: dvbm ctx 1333c911
[ 2.562899] rk_dvbm ffa70000.rkdvbm: probe success
[ 2.626639] rkcifhw ffa10000.rkcif: no iommu attached, using non-iommu buffers
[ 2.626663] rkcifhw ffa10000.rkcif: No reserved memory region assign to CIF
[ 2.627048] rkcif rkcif-mipi-lvds: rkcif driver version: v00.02.00
[ 2.627166] rkcif rkcif-mipi-lvds: attach to cif hw node
[ 2.627181] rkcif rkcif-mipi-lvds: failed to get dphy hw node
[ 2.627191] rkcif rkcif-mipi-lvds: rkcif wait line 0
[ 2.627202] rkcif rkcif-mipi-lvds: rkcif fastboot reserve bufs num 3
[ 2.627215] : terminal subdev does not exist
[ 2.627225] : terminal subdev does not exist
[ 2.627235] : terminal subdev does not exist
[ 2.627243] : terminal subdev does not exist
[ 2.627253] : get_remote_sensor: video pad[0] is null
[ 2.627262] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.627273] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.627281] : get_remote_sensor: video pad[0] is null
[ 2.627289] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.627297] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.627307] : get_remote_sensor: video pad[0] is null
[ 2.627313] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.627321] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.627328] : get_remote_sensor: video pad[0] is null
[ 2.627334] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 2.627342] : rkcif_scale_set_fmt: req(80, 60) src out(0, 0)
[ 2.639780] rkcif rkcif-mipi-lvds: No memory-region-thunderboot specified
[ 2.641013] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 2.641176] rockchip-mipi-csi2-hw ffa20000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 2.641309] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: enter mipi csi2 hw probe!
[ 2.641415] rockchip-mipi-csi2-hw ffa30000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[ 2.641862] rockchip-mipi-csi2 mipi0-csi2: attach to csi2 hw node
[ 2.641927] rkcif rkcif-mipi-lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 2.641944] rockchip-mipi-csi2: Async registered subdev
[ 2.641953] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds!
[ 2.673045] rkisp_hw ffa00000.rkisp: is_thunderboot: 0
[ 2.673071] rkisp_hw ffa00000.rkisp: Missing rockchip,grf property
[ 2.673112] rkisp_hw ffa00000.rkisp: max input:0x0@0fps
[ 2.673303] rkisp_hw ffa00000.rkisp: get sram size:253952
[ 2.673318] rkisp_hw ffa00000.rkisp: no iommu attached, using non-iommu buffers
[ 2.673328] rkisp_hw ffa00000.rkisp: No reserved memory region. default cma area!
[ 2.673731] rkisp rkisp-vir0: rkisp driver version: v02.05.00
[ 2.673857] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 2.678157] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 2.709866] rockchip-csi2-dphy-hw ff3e8000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 2.734504] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 3.096450] rkcif rkcif-mipi-lvds: clear unready subdev num: 2
[ 3.097425] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 3.097449] rkcif-mipi-lvds: Async subdev notifier completed
[ 3.097474] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 3.097483] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
[ 3.097763] rkisp rkisp-vir0: clear unready subdev num: 1
[ 3.097991] rkcif-mipi-lvds: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 3.098008] rkcif-mipi-lvds: There is not terminal subdev, not synchronized with ISP
[ 3.099281] rkisp-vir0: Async subdev notifier completed
[ 3.120508] rga: rga2, irq = 39, match scheduler
[ 3.125516] rga: rga2 hardware loaded successfully, hw_version:3.3.87975.
[ 3.125544] rga: rga2 probe successfully
[ 3.125805] rga_iommu: IOMMU binding successfully, default mapping core[0x4]
[ 3.129954] rga: Module initialized. v1.3.1
[ 3.161454] mpp_vcodec: loading out-of-tree module taints kernel.
[ 3.177886] mpp_vcodec: init new
[ 3.178037] mpp_service mpp-srv: 424abb9b author: Yandong Lin 2024-04-29 [mpp_enc]: fix wrap enc sw timeout when resolution switch
[ 3.178050] mpp_service mpp-srv: probe start
[ 3.179743] mpp_rkvenc_540c ffa50000.rkvenc: probing start
[ 3.180193] mpp_rkvenc_540c ffa50000.rkvenc: probing finish
[ 3.180616] mpp_vepu_pp ffa60000.rkvenc-pp: probe device
[ 3.180886] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_a_pp is not found!
[ 3.180900] vepu_pp_init:526: No aclk reset resource define
[ 3.180911] mpp_vepu_pp ffa60000.rkvenc-pp: shared_rst_h_pp is not found!
[ 3.180917] vepu_pp_init:529: No hclk reset resource define
[ 3.184338] mpp_vepu_pp ffa60000.rkvenc-pp: probing finish
[ 3.184612] mpp_service mpp-srv: probe success
[ 3.208254] RKNPU ff660000.npu: RKNPU: rknpu iommu device-tree entry not found!, using non-iommu mode
[ 3.208658] RKNPU ff660000.npu: RKNPU: Initialized RKNPU driver: v0.9.2 for 20230825
[ 3.208744] RKNPU ff660000.npu: dev_pm_opp_set_regulators: no regulator (rknpu) found: -19
[ 3.251722] rockit_load start
[ 3.275433] rockit_load end
[ 3.292754] rve: rve_irq, irq = 56, match scheduler
[ 3.294852] rve: Driver loaded successfully rve[2] ver:[2021]58.1a
[ 3.294876] rve: probe successfully
[ 3.296896] rve: Module initialized. v1.0.6
[ 3.623377] rk_gmac-dwmac ffa80000.ethernet eth0: PHY [stmmac-0:02] driver [RK630 PHY] (irq=POLL)
[ 3.624230] dwmac4: Master AXI performs any burst length
[ 3.624265] rk_gmac-dwmac ffa80000.ethernet eth0: No Safety Features support found
[ 3.624286] rk_gmac-dwmac ffa80000.ethernet eth0: PTP not supported by HW
[ 3.624592] rk_gmac-dwmac ffa80000.ethernet eth0: configuring for phy/rmii link mode
[ 3.644802] udevd[322]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video0': No such file or directory
[ 3.645994] udevd[323]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video1': No such file or directory
[ 3.647060] udevd[324]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video2': No such file or directory
[ 3.668302] udevd[325]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video3': No such file or directory
[ 3.674123] udevd[329]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video4': No such file or directory
[ 3.675244] udevd[330]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video5': No such file or directory
[ 3.676322] udevd[331]: failed to execute '/lib/udev/v4l_id' 'v4l_id /dev/video6': No such file or directory
[ 4.133818] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.163112] file system registered
[ 4.164937] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.165116] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.165135] cfg80211: failed to load regulatory.db
[ 4.226146] libaes: exports duplicate symbol aes_decrypt (owned by kernel)
[ 4.226482] libaes: exports duplicate symbol aes_decrypt (owned by kernel)
[ 4.244279] using random self ethernet address
[ 4.244307] using random host ethernet address
[ 4.260170] aicbsp_init
[ 4.260191] RELEASE_DATE:2024_0615_c3cb37b3
[ 4.260200] aicbsp_resv_mem_init
[ 4.287179] Mass Storage Function, version: 2009/09/11
[ 4.287209] LUN: removable file: (no medium)
[ 4.437373] read descriptors
[ 4.437449] read strings
[ 4.489529] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 4.489560] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 4.489568] aicbsp: aicbsp_platform_power_on
[ 4.512408] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1 did:0xC08D
[ 4.512569] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1 did:0xC18D
[ 4.512582] aicbsp: aicbsp_sdio_probe after replace:1
[ 4.512591] the device is PRODUCT_ID_AIC8800DC
[ 4.512600] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 50 MHz
[ 4.512606] aicbsp: aicwf_sdio_reg_init
[ 4.512803] aicbsp: Set SDIO Clock 50 MHz
[ 4.516012] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fw_patch_table_8800dc_u02.bin
[ 4.517136] file md5:778b7bc75d5cbb25362914dbfe3e5c84
[ 4.517235] rwnx_plat_bin_fw_upload_android
[ 4.517248] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fw_adid_8800dc_u02.bin
[ 4.517768] file md5:95d10e6288e4d3413c0e3508cb9d711a
[ 4.519554] rwnx_plat_bin_fw_upload_android
[ 4.519577] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fw_patch_8800dc_u02.bin
[ 4.520929] file md5:ed2c9ffc08e925f38f4a3f5f6f7b5326
[ 4.533646] aicbt_patch_table_load bt btmode[1]:1
[ 4.533665] aicbt_patch_table_load bt uart_baud[1]:1500000
[ 4.533673] aicbt_patch_table_load bt uart_flowctrl[1]:1
[ 4.533679] aicbt_patch_table_load bt lpm_enable[1]:0
[ 4.533685] aicbt_patch_table_load bt tx_pwr[1]:28463
[ 4.538729] aicbsp: bt patch version: - Apr 09 2024 14:03:22 - git c701fdd
[ 4.538806] ############ aicwifi_init begin
[ 4.542874] ############ system_config_8800dc done
[ 4.542887] u02 is loaing ###############
[ 4.542895] rwnx_plat_bin_fw_upload_android
[ 4.542905] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fmacfw_patch_8800dc_u02.bin
[ 4.544647] file md5:d585f255ef3205e733761ba715a85ba7
[ 4.551562] aicwf_dpd_calib_8800dc
[ 4.552368] rwnx_plat_bin_fw_upload_android
[ 4.552385] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fmacfw_calib_8800dc_u02.bin
[ 4.554501] file md5:578501435702663ab4aba9f78722c971
[ 4.785134] ############ rwnx_plat_patch_load done
[ 4.787431] ### Upload fmacfw_patch_tbl_8800dc_u02.bin
[ 4.787447] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fmacfw_patch_tbl_8800dc_u02.bin
[ 4.800636] file md5:f5f4baabb44f766e424f27b38ca7b882
[ 4.800655] tbl size = 816
[ 4.800929] zh May 28 2024 20:54:45 - g2db9716
[ 4.800938] patch_tbl: 110888 180e81
[ 4.816912] patch_tbl: 40030080 f
[ 4.817060] patch_tbl: 4010001c 0
[ 4.817219] ############ aicwf_patch_config_8800dc done
[ 4.821637] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 50 MHz
[ 4.821657] aicsdio: aicwf_sdio_reg_init
[ 4.826871] aicbsp: aicbsp_resv_mem_alloc_skb, alloc resv_mem_txdata succuss, id: 0, size: 98304
[ 4.827156] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 50 MHz
[ 4.827336] tcp_ack_init
[ 4.858093] aicbsp: sdio_err:<aicwf_sdio_bus_pwrctl,1403>: bus down
[ 5.070619] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 1
[ 5.072626] ieee80211 phy0:
[ 5.072626] *******************************************************
[ 5.072626] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
[ 7.136229] aic_bluetooth_mod_init
[ 7.136597] -->rfkill_bluetooth_init
[ 7.136735] <--rfkill_bluetooth_init
[ 9.292876] rwnx_send_sm_connect_req drv_vif_index:0 connect to UGE1BE(6) channel:2437 auth_type:0
[ 10.240895] of_dma_request_slave_channel: dma-names property of node '/serial@ff4b0000' missing or empty
[ 10.240934] dw-apb-uart ff4b0000.serial: failed to request DMA, use interrupt mode
[ 56.514129] 32I did however load the firmware that was generated for Luckfox Pico Ultra board (with
./build.sh lunchWas anyone successful bringing up LTE connection over USB?
