Creating an image of a LuckFox Pico Ultra W
Posted: 2025-05-12 7:10
by akabob
Hello, I have installed ubuntu, set up the peripherals, installed Python 3.x set up my cronjobs etc. I now wish to deploy a number of LuckFox Ultra W's and I want to take the first device I created an make an image of the EMMC on the board in order that I can clone it to other boards and make the minimal amount of changes to deploy it.
My question is there anyway of making an image of the board using the tools and then copy it on to other boards as required?
Thanks in advance
AkaBoB
Re: Creating an image of a LuckFox Pico Ultra W
Posted: 2025-05-13 1:37
Hello, although we are no longer able to provide support for the Ubuntu system due to licensing issues, the latest SDK includes luckfox-config, which is compatible with Ubuntu. The latest version of luckfox-config supports backing up the rootfs in ext4 format, and allows you to back up the system either to local storage (if there is sufficient space) or to a USB drive (which needs to be mounted in advance to /mnt/udisk).
Posted: 2025-05-13 6:44
by akabob
Crocodile, thank you for your response.
I will give this a try and see how I get on.
Regards
AkaBoB
Posted: 2025-05-21 11:53
by marek
hi, pls, can u tell me how in luckfox-config i can backup emmc rootfs.img ?
Posted: 2025-05-22 11:12
Hello, the steps for EMMC backup are: luckfox-config -> Backup -> rootfs -> Select the storage medium (if using USB, you need to switch to host mode and mount the USB drive to /mnt/udisk first), then wait for the backup to complete.
Posted: 2025-05-22 11:20
by marek
thanks for answer. Does this aplies to newest ubuntu sdk ? because i installed SDK Ubuntu 22.04.5 LTS (GNU/Linux 5.10.160 armv7l) and theres no option for backup when i run luckfox-config.
Posted: 2025-05-22 12:41
Regrettably, at present, due to authorization issues, we are unable to provide support for Ubuntu-related matters. However, you can try replace the /usr/bin/luckfox-config on the board with the latest luckfox-config (the system needs to install rsync)
