1. 开发板的具体型号(RV1103和RV1106是SOC型号)。
Luckfox Nova W
2. 烧录的系统及遇到的问题。
SDK的PREEMPT-RT补丁打了之后进行编译, 出现报错, kernel版本5.10.198, 按照patch顺序打上去的. 3. 您的操作步骤和过程。
把docs/Patches/Real-Time-Performance/PREEMPT_RT/kernel-5.10/5.10.198文件夹里的patch文件按0001到0005打完之后, clean完重新编译出现报错.
4. 请附上报错截图、串口日志和硬件连接图。
# 2025-05-14 16:15:14
# run func: build_hook kernel
[36mToolchain for kernel:[0m
[36m/home/yakecanlee/luckfox_nova_sdk/prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-[0m
[36m==========================================[0m
[36m Start building kernel[0m
[35m+ make -C /home/yakecanlee/luckfox_nova_sdk/kernel/ -j21 CROSS_COMPILE=/home/yakecanlee/luckfox_nova_sdk/prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu- ARCH=arm64 luckfox_linux_defconfig[0m
make[1]: Entering directory '/home/yakecanlee/luckfox_nova_sdk/kernel'
# No change to .config
make[1]: Leaving directory '/home/yakecanlee/luckfox_nova_sdk/kernel'
[35m+ make -C /home/yakecanlee/luckfox_nova_sdk/kernel/ -j21 CROSS_COMPILE=/home/yakecanlee/luckfox_nova_sdk/prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu- ARCH=arm64 luckfox-rk3308b-evb-v10.img[0m
CALL scripts/atomic/check-atomics.sh
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
AR kernel/livepatch/built-in.a
CC kernel/rcu/update.o
AR kernel/entry/built-in.a
CC kernel/dma/mapping.o
CC kernel/cgroup/cgroup.o
CC kernel/time/time.o
CC kernel/futex/core.o
CC kernel/trace/trace_clock.o
CC kernel/events/core.o
CC kernel/sched/core.o
CC kernel/time/timer.o
CC arch/arm64/kernel/fpsimd.o
CC kernel/dma/direct.o
CC kernel/cgroup/rstat.o
CC kernel/rcu/sync.o
CC kernel/fork.o
CC kernel/bpf/core.o
CC net/core/sock.o
AR virt/lib/built-in.a
AR virt/built-in.a
AS arch/arm64/lib/clear_page.o
AS arch/arm64/lib/clear_user.o
AS arch/arm64/lib/copy_from_user.o
CC lib/math/div64.o
AS arch/arm64/lib/copy_in_user.o
CC kernel/cgroup/namespace.o
AS arch/arm64/lib/copy_page.o
AR kernel/trace/built-in.a
CC kernel/exec_domain.o
CC lib/math/gcd.o
AS arch/arm64/lib/copy_to_user.o
CC arch/arm64/lib/csum.o
CC kernel/dma/coherent.o
CC lib/math/lcm.o
CC lib/math/int_pow.o
CC kernel/rcu/srcutree.o
CC kernel/dma/swiotlb.o
CC kernel/cgroup/cgroup-v1.o
CC kernel/cgroup/freezer.o
CC lib/math/int_sqrt.o
CC kernel/time/hrtimer.o
arch/arm64/kernel/fpsimd.c: In function 'sve_set_vector_length':
arch/arm64/kernel/fpsimd.c:639:2: error: implicit declaration of function 'sve_free'; did you mean 'vfree'? [-Werror=implicit-function-declaration]
639 | sve_free(task);
| vfree
arch/arm64/kernel/fpsimd.c: In function 'fpsimd_release_task':
arch/arm64/kernel/fpsimd.c:919:2: error: implicit declaration of function '__sve_free' [-Werror=implicit-function-declaration]
919 | __sve_free(dead_task);
cc1: all warnings being treated as errors
make[4]: *** [scripts/Makefile.build:273: arch/arm64/kernel/fpsimd.o] Error 1
make[3]: *** [scripts/Makefile.build:516: arch/arm64/kernel] Error 2
make[2]: *** [Makefile:1929: arch/arm64] Error 2
make[2]: *** Waiting for unfinished jobs....
CC kernel/time/timekeeping.o
CC kernel/time/ntp.o
CC net/ethernet/eth.o
CC lib/math/reciprocal_div.o
CC arch/arm64/lib/delay.o
AS arch/arm64/lib/memchr.o
CC kernel/panic.o
AS arch/arm64/lib/memcmp.o
CC lib/math/rational.o
CC kernel/dma/pool.o
AS arch/arm64/lib/memcpy.o
AR lib/math/built-in.a
CC lib/crypto/chacha.o
AS arch/arm64/lib/memmove.o
AS arch/arm64/lib/memset.o
CC kernel/dma/remap.o
CC kernel/rcu/tree.o
CC lib/crypto/aes.o
CC kernel/rcu/rcu_segcblist.o
AR kernel/futex/built-in.a
CC kernel/cpu.o
CC kernel/exit.o
CC kernel/time/clocksource.o
AS arch/arm64/lib/strchr.o
AR kernel/bpf/built-in.a
AS arch/arm64/lib/strcmp.o
AS arch/arm64/lib/strlen.o
CC kernel/softirq.o
CC kernel/resource.o
AS arch/arm64/lib/strncmp.o
AS arch/arm64/lib/strnlen.o
AS arch/arm64/lib/strrchr.o
AR net/ethernet/built-in.a
AR net/802/built-in.a
CC net/sched/sch_generic.o
CC net/sched/sch_mq.o
CC net/netlink/af_netlink.o
CC net/netlink/genetlink.o
CC kernel/sysctl.o
AS arch/arm64/lib/tishift.o
CC lib/crypto/arc4.o
AS arch/arm64/lib/crc32.o
AR kernel/dma/built-in.a
CC kernel/capability.o
AR arch/arm64/lib/lib.a
CC kernel/ptrace.o
AR arch/arm64/lib/built-in.a
CC kernel/time/jiffies.o
AR kernel/cgroup/built-in.a
CC kernel/user.o
kernel/sched/core.c: In function 'drain_rq_cpu_stop':
kernel/sched/core.c:7781:2: error: implicit declaration of function 'migrate_tasks'; did you mean 'migrate_pages'? [-Werror=implicit-function-declaration]
7781 | migrate_tasks(rq, &rf, false);
| migrate_pages
make[4]: *** [scripts/Makefile.build:273: kernel/sched/core.o] Error 1
make[3]: *** [scripts/Makefile.build:516: kernel/sched] Error 2
make[3]: *** Waiting for unfinished jobs....
CC kernel/time/timer_list.o
CC kernel/time/timeconv.o
CC kernel/time/timecounter.o
CC lib/crypto/blake2s.o
CC kernel/time/alarmtimer.o
CC net/core/request_sock.o
CC net/core/skbuff.o
CC kernel/time/posix-timers.o
CC kernel/time/posix-cpu-timers.o
CC kernel/time/posix-clock.o
CC kernel/time/itimer.o
CC kernel/time/clockevents.o
CC kernel/time/tick-common.o
CC lib/crypto/blake2s-generic.o
CC lib/crypto/sha256.o
AR net/bpf/built-in.a
CC net/ethtool/ioctl.o
CC net/core/datagram.o
CC net/ipv4/route.o
CC net/ethtool/common.o
CC kernel/time/tick-broadcast.o
CC net/ipv4/inetpeer.o
CC net/ipv4/protocol.o
CC kernel/time/tick-broadcast-hrtimer.o
CC kernel/time/sched_clock.o
CC kernel/time/tick-oneshot.o
CC kernel/time/tick-sched.o
CC net/ipv4/ip_input.o
CC kernel/time/vsyscall.o
AR net/sched/built-in.a
CC kernel/time/timekeeping_debug.o
AR lib/crypto/built-in.a
CC net/xfrm/xfrm_policy.o
CC lib/zlib_inflate/inffast.o
CC lib/zlib_inflate/inflate.o
CC lib/zlib_inflate/infutil.o
CC lib/zlib_inflate/inftrees.o
CC net/ethtool/netlink.o
CC net/ethtool/bitset.o
CC net/ethtool/strset.o
CC net/ethtool/linkinfo.o
AR kernel/rcu/built-in.a
CC net/netlink/policy.o
CC lib/zlib_inflate/inflate_syms.o
CC net/ipv4/ip_fragment.o
CC net/ipv4/ip_forward.o
CC net/unix/af_unix.o
AR kernel/time/built-in.a
CC net/ipv4/ip_options.o
CC net/unix/garbage.o
CC net/unix/sysctl_net_unix.o
CC lib/zlib_deflate/deflate.o
CC kernel/events/ring_buffer.o
AR lib/zlib_inflate/built-in.a
CC lib/zlib_deflate/deftree.o
CC lib/zlib_deflate/deflate_syms.o
CC net/core/stream.o
AR net/netlink/built-in.a
CC net/core/scm.o
CC net/core/gen_stats.o
CC net/ipv6/af_inet6.o
CC net/ipv6/anycast.o
CC net/ipv6/ip6_output.o
CC net/ethtool/linkmodes.o
CC net/ethtool/linkstate.o
AR lib/zlib_deflate/built-in.a
CC net/ethtool/debug.o
CC lib/reed_solomon/reed_solomon.o
CC net/unix/scm.o
CC net/ethtool/wol.o
CC net/ipv4/ip_output.o
CC net/ipv4/ip_sockglue.o
CC net/ethtool/features.o
CC net/ipv4/inet_hashtables.o
CC net/ipv4/inet_timewait_sock.o
CC net/ipv4/inet_connection_sock.o
CC kernel/events/callchain.o
CC net/core/gen_estimator.o
AR lib/reed_solomon/built-in.a
CC lib/zstd/huf_decompress.o
CC net/core/net_namespace.o
CC net/ethtool/privflags.o
CC net/core/secure_seq.o
CC net/ethtool/rings.o
CC net/ipv6/ip6_input.o
CC net/ipv6/addrconf.o
CC net/ethtool/channels.o
CC net/ethtool/coalesce.o
CC net/ipv6/addrlabel.o
AR net/unix/built-in.a
CC net/xfrm/xfrm_state.o
CC net/packet/af_packet.o
CC net/key/af_key.o
CC kernel/events/hw_breakpoint.o
CC net/ethtool/pause.o
CC net/core/flow_dissector.o
CC net/core/sysctl_net_core.o
CC net/ethtool/eee.o
CC net/core/dev.o
CC net/ethtool/tsinfo.o
CC net/ethtool/cabletest.o
CC net/ipv4/tcp.o
CC net/core/dev_addr_lists.o
CC lib/zstd/decompress.o
CC net/core/dst.o
CC net/ipv4/tcp_input.o
AR kernel/events/built-in.a
CC net/ipv4/tcp_output.o
make[2]: *** [Makefile:1929: kernel] Error 2
CC net/ipv6/route.o
CC net/ipv4/tcp_timer.o
CC net/ethtool/tunnels.o
CC net/ipv6/ip6_fib.o
CC net/ipv6/ipv6_sockglue.o
CC net/ipv6/ndisc.o
CC net/ipv6/udp.o
CC net/core/netevent.o
CC net/core/neighbour.o
CC net/core/rtnetlink.o
CC net/xfrm/xfrm_hash.o
CC net/core/utils.o
CC net/core/link_watch.o
AR net/key/built-in.a
CC net/core/filter.o
CC net/ipv4/tcp_ipv4.o
AR net/packet/built-in.a
CC net/bluetooth/rfcomm/core.o
AR net/ethtool/built-in.a
CC net/bluetooth/rfcomm/sock.o
CC net/wireless/core.o
CC net/xfrm/xfrm_input.o
CC net/ipv6/udplite.o
CC net/core/sock_diag.o
CC net/ipv6/raw.o
CC net/ipv6/icmp.o
CC lib/zstd/entropy_common.o
CC net/ipv6/mcast.o
CC net/core/dev_ioctl.o
CC lib/zstd/fse_decompress.o
CC net/core/tso.o
CC net/core/sock_reuseport.o
CC net/core/fib_notifier.o
CC net/bluetooth/rfcomm/tty.o
CC net/ipv4/tcp_minisocks.o
CC lib/zstd/zstd_common.o
CC net/xfrm/xfrm_output.o
CC net/ipv4/tcp_cong.o
AR lib/zstd/built-in.a
CC lib/mpi/generic_mpih-lshift.o
CC net/wireless/sysfs.o
CC net/core/xdp.o
CC net/ipv4/tcp_metrics.o
CC net/ipv6/reassembly.o
CC net/core/flow_offload.o
CC net/ipv4/tcp_fastopen.o
CC net/ipv6/tcp_ipv6.o
CC net/ipv6/ping.o
CC lib/mpi/generic_mpih-mul1.o
CC lib/mpi/generic_mpih-mul2.o
CC lib/mpi/generic_mpih-mul3.o
CC net/ipv6/exthdrs.o
CC net/ipv6/datagram.o
CC net/wireless/radiotap.o
CC net/core/net-sysfs.o
CC net/ipv4/tcp_rate.o
AR net/bluetooth/rfcomm/built-in.a
CC net/bluetooth/hidp/core.o
CC lib/mpi/generic_mpih-rshift.o
CC net/bluetooth/hidp/sock.o
CC lib/mpi/generic_mpih-sub1.o
CC lib/mpi/generic_mpih-add1.o
CC lib/mpi/ec.o
CC net/ipv4/tcp_recovery.o
CC net/xfrm/xfrm_sysctl.o
CC net/core/page_pool.o
CC lib/mpi/mpicoder.o
CC lib/mpi/mpi-add.o
CC net/wireless/util.o
CC net/ipv6/ip6_flowlabel.o
CC net/wireless/reg.o
CC net/ipv4/tcp_ulp.o
CC net/ipv4/tcp_offload.o
CC lib/mpi/mpi-bit.o
CC net/ipv4/datagram.o
CC net/ipv6/inet6_connection_sock.o
CC net/ipv6/udp_offload.o
CC net/core/net-procfs.o
CC lib/mpi/mpi-cmp.o
CC lib/mpi/mpi-sub-ui.o
CC lib/mpi/mpi-div.o
CC net/ipv6/seg6.o
AR net/bluetooth/hidp/built-in.a
CC net/core/ptp_classifier.o
CC net/bluetooth/af_bluetooth.o
CC lib/mpi/mpi-inv.o
CC net/core/gro_cells.o
CC net/xfrm/xfrm_replay.o
CC net/ipv4/raw.o
CC net/ipv6/fib6_notifier.o
CC net/ipv4/udp.o
CC net/ipv6/rpl.o
CC net/ipv6/sysctl_net_ipv6.o
CC net/ipv4/udplite.o
CC lib/mpi/mpi-mod.o
CC net/ipv4/udp_offload.o
CC net/ipv6/xfrm6_policy.o
CC net/ipv4/arp.o
CC net/ipv4/icmp.o
CC lib/mpi/mpi-mul.o
CC lib/mpi/mpih-cmp.o
CC net/ipv6/xfrm6_state.o
CC lib/mpi/mpih-div.o
CC net/ipv6/xfrm6_input.o
CC net/wireless/scan.o
CC net/wireless/nl80211.o
AR net/core/built-in.a
CC net/mac80211/main.o
CC net/bluetooth/hci_core.o
CC lib/mpi/mpih-mul.o
CC lib/mpi/mpi-pow.o
CC net/wireless/mlme.o
CC net/ipv6/xfrm6_output.o
CC net/ipv6/xfrm6_protocol.o
CC net/ipv6/proc.o
CC net/xfrm/xfrm_device.o
CC net/ipv4/devinet.o
CC net/ipv6/syncookies.o
CC lib/mpi/mpiutil.o
CC net/ipv6/addrconf_core.o
CC net/ipv4/af_inet.o
CC net/ipv4/igmp.o
CC net/ipv4/fib_frontend.o
CC net/ipv4/fib_semantics.o
CC net/ipv6/exthdrs_core.o
CC net/ipv6/ip6_checksum.o
CC net/ipv4/fib_trie.o
CC net/ipv6/ip6_icmp.o
AR lib/mpi/built-in.a
CC lib/argv_split.o
CC net/wireless/ibss.o
CC net/ipv6/output_core.o
CC net/xfrm/xfrm_algo.o
CC net/ipv6/protocol.o
CC net/ipv6/ip6_offload.o
CC net/ipv6/tcpv6_offload.o
CC net/mac80211/status.o
CC lib/bug.o
CC lib/clz_tab.o
CC lib/cmdline.o
CC net/ipv4/fib_notifier.o
CC net/ipv6/exthdrs_offload.o
CC net/ipv6/inet6_hashtables.o
CC net/ipv6/mcast_snoop.o
CC lib/cpumask.o
CC net/wireless/sme.o
CC lib/ctype.o
CC lib/dec_and_lock.o
CC lib/decompress.o
CC net/ipv4/inet_fragment.o
CC net/ipv4/ping.o
CC net/ipv4/ip_tunnel_core.o
CC net/ipv4/gre_offload.o
CC lib/decompress_inflate.o
AR net/xfrm/built-in.a
CC lib/decompress_unzstd.o
CC net/bluetooth/hci_conn.o
CC net/bluetooth/hci_event.o
CC net/rfkill/core.o
CC net/rfkill/rfkill-wlan.o
CC net/rfkill/rfkill-bt.o
CC lib/dump_stack.o
CC lib/earlycpio.o
CC net/ipv4/metrics.o
CC net/ipv4/netlink.o
CC net/ipv4/nexthop.o
CC lib/extable.o
CC lib/fdt.o
CC lib/fdt_addresses.o
CC net/mac80211/driver-ops.o
AR net/ipv6/built-in.a
CC lib/fdt_empty_tree.o
CC net/ipv4/udp_tunnel_stub.o
CC net/wireless/chan.o
CC lib/fdt_ro.o
CC lib/fdt_rw.o
CC lib/fdt_strerror.o
CC lib/fdt_sw.o
CC net/ipv4/sysctl_net_ipv4.o
CC lib/fdt_wip.o
CC lib/flex_proportions.o
CC net/wireless/ethtool.o
CC lib/idr.o
CC net/wireless/mesh.o
CC lib/irq_regs.o
CC net/wireless/ap.o
CC lib/is_single_threaded.o
CC net/wireless/trace.o
CC net/ipv4/proc.o
CC lib/klist.o
AR net/rfkill/built-in.a
CC net/ipv4/syncookies.o
CC net/devres.o
CC lib/kobject.o
CC net/socket.o
CC net/ipv4/tcp_cubic.o
CC lib/kobject_uevent.o
CC lib/logic_pio.o
CC net/bluetooth/mgmt.o
CC net/ipv4/xfrm4_policy.o
CC net/ipv4/xfrm4_state.o
CC lib/memcat_p.o
CC net/compat.o
CC net/wireless/ocb.o
CC net/mac80211/sta_info.o
CC net/wireless/pmsr.o
CC net/mac80211/wep.o
CC net/wireless/of.o
GEN net/wireless/shipped-certs.c
CC net/wireless/wext-core.o
CC lib/memneq.o
CC lib/nmi_backtrace.o
CC lib/nodemask.o
CC net/ipv4/xfrm4_input.o
CC net/ipv4/xfrm4_output.o
CC lib/plist.o
CC net/ipv4/xfrm4_protocol.o
CC lib/radix-tree.o
CC lib/ratelimit.o
CC lib/rbtree.o
CC lib/seq_buf.o
CC lib/sha1.o
CC lib/show_mem.o
CC lib/siphash.o
CC net/wireless/wext-proc.o
CC lib/string.o
CC net/wireless/wext-priv.o
CC net/wireless/shipped-certs.o
CC lib/timerqueue.o
CC net/sysctl_net.o
CC lib/vsprintf.o
CC lib/win_minmax.o
CC lib/xarray.o
CC lib/lockref.o
CC net/mac80211/aead_api.o
CC net/mac80211/wpa.o
CC lib/bcd.o
CC lib/sort.o
CC lib/parser.o
CC net/mac80211/scan.o
CC net/mac80211/offchannel.o
CC lib/debug_locks.o
CC net/mac80211/ht.o
CC lib/random32.o
CC lib/bust_spinlocks.o
CC lib/kasprintf.o
CC lib/bitmap.o
CC lib/scatterlist.o
CC lib/list_sort.o
CC lib/uuid.o
CC net/mac80211/agg-tx.o
AR net/ipv4/built-in.a
CC net/mac80211/agg-rx.o
CC net/mac80211/vht.o
CC lib/iov_iter.o
CC lib/clz_ctz.o
CC lib/bsearch.o
CC lib/find_bit.o
CC net/mac80211/he.o
CC lib/llist.o
CC lib/memweight.o
CC net/mac80211/s1g.o
CC lib/kfifo.o
CC lib/percpu-refcount.o
CC lib/rhashtable.o
CC net/mac80211/ibss.o
CC lib/once.o
CC net/mac80211/iface.o
CC lib/refcount.o
CC lib/usercopy.o
CC lib/errseq.o
CC net/mac80211/rate.o
CC net/mac80211/michael.o
AR net/wireless/built-in.a
CC net/mac80211/tkip.o
CC lib/bucket_locks.o
CC lib/generic-radix-tree.o
CC net/mac80211/aes_cmac.o
CC lib/string_helpers.o
CC net/mac80211/aes_gmac.o
CC net/mac80211/fils_aead.o
CC lib/hexdump.o
CC lib/kstrtox.o
CC net/mac80211/cfg.o
CC net/mac80211/ethtool.o
CC net/mac80211/rx.o
CC net/mac80211/spectmgmt.o
CC net/mac80211/tx.o
CC lib/iomap_copy.o
CC lib/pci_iomap.o
CC lib/devres.o
CC net/mac80211/key.o
CC net/bluetooth/hci_sock.o
CC net/mac80211/util.o
CC lib/hweight.o
CC lib/assoc_array.o
CC lib/bitrev.o
CC lib/linear_ranges.o
CC lib/crc16.o
HOSTCC lib/gen_crc32table
CC lib/xxhash.o
CC lib/genalloc.o
CC net/mac80211/wme.o
CC net/mac80211/chan.o
CC net/mac80211/trace.o
CC net/bluetooth/hci_sysfs.o
CC net/mac80211/mlme.o
CC lib/percpu_counter.o
CC net/mac80211/tdls.o
CC net/mac80211/ocb.o
CC net/mac80211/airtime.o
CC lib/syscall.o
CC lib/errname.o
CC net/mac80211/pm.o
CC lib/nlattr.o
CC lib/checksum.o
CC lib/cpu_rmap.o
CC lib/dynamic_queue_limits.o
CC lib/glob.o
CC lib/strncpy_from_user.o
CC lib/strnlen_user.o
CC lib/net_utils.o
CC lib/sg_pool.o
CC net/bluetooth/l2cap_core.o
CC net/mac80211/rc80211_minstrel.o
CC net/bluetooth/l2cap_sock.o
CC net/mac80211/rc80211_minstrel_ht.o
CC lib/asn1_decoder.o
GEN lib/oid_registry_data.c
CC lib/sbitmap.o
AR lib/lib.a
GEN lib/crc32table.h
CC lib/oid_registry.o
CC lib/crc32.o
CC net/bluetooth/smp.o
CC net/bluetooth/lib.o
CC net/bluetooth/ecdh_helper.o
CC net/bluetooth/hci_request.o
CC net/bluetooth/mgmt_util.o
CC net/bluetooth/mgmt_config.o
CC net/bluetooth/sco.o
CC net/bluetooth/hci_debugfs.o
AR lib/built-in.a
AR net/mac80211/built-in.a
AR net/bluetooth/built-in.a
AR net/built-in.a
make[1]: *** [arch/arm64/Makefile:214: luckfox-rk3308b-evb-v10.img] Error 2
[31mERROR: Running /home/yakecanlee/luckfox_nova_sdk/device/rockchip/common/build-hooks/10-kernel.sh - run_command failed
