PWM capture mode
  • Hello, the capture mode of PWM is enabled by default. After inputting the PWM signal to the pin, you can view it by using the command.
    # X should be adjusted according to the actual situation
    echo 0 > /sys/class/pwm/pwmchipX/export
    cat /sys/class/pwm/pwmchipX/pwm0/capture
    Note: Once the "enable" setting is set to 1, the system will enter the output mode and will no longer be able to capture.
    echo 1 >  /sys/class/pwm/pwmchipX/pwm0/enable
  • Thanks!!!
