Increase SPI buffer size
Posted: 2025-06-12 22:40
by kornpow
I am trying to increase the buffer size of the SPI driver, to be greater than `4096`.
[root@luckfox ]# cat /sys/module/spidev/parameters/bufsiz
4096
I've recompiled with the below change. But it didn't do what I wanted.
--- a/sysdrv/source/kernel/arch/arm/boot/dts/rv1103g-luckfox-pico.dts
+++ b/sysdrv/source/kernel/arch/arm/boot/dts/rv1103g-luckfox-pico.dts
@@ -119,9 +119,13 @@ &usbdrd_dwc3 {
/**********SPI**********/
/* SPI0_M0 */
&spi0 {
- status = "disabled";
+ status = "okay";
spidev@0 {
+ /* Large buffer configuration */
+ bufsiz = <250000>; /* 128KB */
+ rx-buffer-size = <250000>;
+ tx-buffer-size = <250000>;
Can you please let me know how to update this value?
Re: Increase SPI buffer size
Posted: 2025-06-13 7:26
Hello, the driver source code of spidev does not support the bufsiz attribute. You can directly refer to the source code of sysdrv/source/kernel/drivers/spi/spidev.c. The bbufsiz is registered to sysfs using the code "module_param(bufsiz, uint, S_IRUGO);" By default, it is 4096 and the user layer only has read permission. You can modify the spidev driver according to your actual needs.
