RV1103同时录音和播放音频失败
Posted: 2025-06-15 9:24
by S_crossroad
如题,按照simple_adec_bind_ao.c和simple_ai_bind_aenc.c文件中的函数,写了录音和播放音频的逻辑。我希望能同时录音和播放音频。但是初始化的时候报错了,报错内容如下。
[param.c][rk_param_init]:g_ini_path_ is /oem/usr/share/rkipc-300w.ini
log_file = (nil)
RTVersion        09:09:53-523 {dump              :064} ---------------------------------------------------------
RTVersion        09:09:53-523 {dump              :065} rockit version: git-4720dc10a Tue Apr 30 15:47:55 2024 +0800
RTVersion        09:09:53-523 {dump              :066} rockit building: built- 2024-04-30 15:53:43
RTVersion        09:09:53-523 {dump              :067} ---------------------------------------------------------
(null)           09:09:53-523 {log_level_init    :207}
 please use echo name=level > /tmp/rt_log_level set log level
        name: all cmpi mb sys vdec venc rgn vpss vgs tde avs wbc vo vi ai ao aenc adec
        log_level: 0 1 2 3 4 5 6
(null)           09:09:53-523 {read_log_level    :098} text is all=4
(null)           09:09:53-524 {read_log_level    :100} module is all, log_level is 4
[audio.c][rkipc_ai_init]:aiAttr.u8CardName is hw:0,0
RKAiChn          09:09:53-527 {prepareGraph      :213} check enabled - file_read:0 vqe:0 aed:0 bcd:0 buz:0 gbs:0
(null)           09:09:53-529 {monitor_log_level :149} #Start monitor_log_level thread, arg:(nil)
[audio.c][rkipc_ao_init]:aoAttr.u8CardName is hw:0,0
cannot set hw params: Invalid argument
TinyAlsaHardWare 09:09:53-658 {tinyalsa_pcm_get_e:052} fail to tinyalsa_open_snd, error:cannot set hw params: Invalid argument
RTTaskNodeBase   09:09:53-658 {prepareForRun     :485} task node 0 open failed!
RTTaskGraph      09:09:53-658 {prepareNodeForRun :295} failed to prepareNodeForRun(id=0)! interrupt running
RTTaskGraph      09:09:53-658 {prepare           :364} task graph prepare for run failed!, ret=-10
[audio.c][rkipc_ao_init]:RK_MPI_AO_EnableChn fail 0xa00b8010
u32Channels 1 u32SampleRate 8000 enBitwidth 1cmpi             09:09:53-659 {ao_enable_resample:298} Not found channel(dev 0, chn 0)
cmpi             09:09:53-659 {rkipc_ao_init     :583} ao enable channel fail, reason = a00b8002, aoChn = 0
=======rkipc_adec_init=======
[audio.c][rkipc_audio_init]:RK_MPI_SYS_Bind fail ffffffff
cmpi             09:09:53-664 {ao_get_chn_info   :679} Not found channel(dev 0, chn 0)
Bind ADEC[0] to AO[0] failed! ret=-1610448888
是否输入和输出不能用同一个u8CardName?还是不能用相同的dev_id和chn_id? 我现在根据audio.c文件中的定义,是这么赋值的
static int ai_dev_id = 0;
static int ai_chn_id = 0;
static int aenc_dev_id = 0;
static int aenc_chn_id = 0;
static int ao_dev_id = 0;
static int ao_chn_id = 0;
static int adec_dev_id = 0;
static int adec_chn_id = 0;
如果不对的话,该怎么初始化呢?
Re: RV1103同时录音和播放音频失败
Posted: 2025-06-16 8:49
by Luckfox Taylor
我们提供了支持音频功能的相关开发板,具体信息请参考相应的软件部分。由于工程师的工作量有限,我们目前无法为个人项目提供技术支持,敬请谅解。
