The goodix touchscreen is configured at i2c address 0x14 in the dts (sysdrv/source/kernel/arch/arm/boot/dts/rv1106-luckfox-pico-86panel-ipc.dtsi in the SDK, lines 281ff).
However, sometimes the goodix chip appears at i2c address 0x5d (visible with i2cdetect 3). This is the alternate i2c address of the touchscreen chip when the IRQ line (connected to PA0) is logic low during reset (PD0).
Unfortunately, we don't seem to have a schematic diagram of the 86panel, so it's not totally clear how goodix IRQ is connected. But I guess it is just connected to PA0 without a pullup.
So my question is: shouldn't the pinctrl setup in the dts (line 305 in sysdrv/source/kernel/arch/arm/boot/dts/rv1106-luckfox-pico-86panel-ipc.dtsi) configure a pullup on the IRQ line to make sure it is not floating and always high when the goodix chip is reset? Like:
tp_irq:tp-irq {
rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>;
Update: Yes
