你好如果我想把docker install 到 pico ultra 應用以下連結的 https://wiki.luckfox.com/Luckfox-Pico/Core3566-SDK/
但我見到我永遠不成功並出現下列信息, 是有何原因呢
× docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2025-06-26 14:35:01 CST; 1min 41s ago
TriggeredBy: × docker.socket
Docs: https://docs.docker.com
Process: 2846 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status>
Main PID: 2846 (code=exited, status=1/FAILURE)
CPU: 665ms
Jun 26 14:35:01 luckfox systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Jun 26 14:35:01 luckfox systemd[1]: Stopped Docker Application Container Engine.
Jun 26 14:35:01 luckfox systemd[1]: docker.service: Start request repeated too quickly.
Jun 26 14:35:01 luckfox systemd[1]: docker.service: Failed with result 'exit-code'.
Jun 26 14:35:01 luckfox systemd[1]: Failed to start Docker Application Container Engine.
pico ultra docker
您好,您所参考的wiki是在X86平台搭建基于docker的开发环境而不是在板端部署docker,Luckfox pico Ultra 的内存有限运行docker的效果不理想我们不做推荐
同时我还注意到您参考的wiki是旧版本的,新版本的wiki地址在https://wiki.luckfox.com/Luckfox-Pico/Luckfox-Pico-SDK/
