Thank you for the reply.
I tried that example and it does not work on the Pico Ultra.
./opencv-mobile-test
opencv-mobile MIPI CSI camera with v4l2 rkaiq
opencv-mobile HW JPG encoder with rk mpp
Still Image Capture Example..
devpath = /dev/video11
driver = rkisp_v7
card = rkisp_mainpath
version = 20500
capabilities = 84201000
device_caps = 4201000
fmt = UYVY 4:2:2 59565955
fmt = Y/CbCr 4:2:2 3631564e
fmt = Y/CrCb 4:2:2 3136564e
fmt = Y/CrCb 4:2:0 3132564e
size = 32 x 32 ~ 2304 x 1296 (+8 +8)
fmt = Y/CbCr 4:2:0 3231564e
rkaiq log level ff1
XCORE:K:rk_aiq_init_lib, ISP HW ver: 32
XCORE:K:
************************** VERSION INFOS **************************
version release date: 2024-2-18
AIQ: AIQ v5.0x5.0
git logs:
25bd14e RV1106: smart_door: release rga/isp/mpp for V1.3.0
99d080a RV1106/RV1103: Battery/Doorbell: release kmpp/rockit-ko for V1.3.2
6458e2a RV1106/RV1103: Battery/Doorbell: release kmpp/rockit-ko for V1.3.1
e8dab39 RV1106: CVR: release rga/isp/mpp for V1.1.0
a021b32 RV1106/RV1103: Battery/Doorbell: release kmpp/rockit-ko for V1.3.0
************************ VERSION INFOS END ************************
XCORE:K:rk_aiq_uapi_sysctl_preInit_scene: main_scene: normal, sub_scene: day
XCORE:E:invalid main scene len!
Looking at the code, I am unsure how this could work. OpenCV assumes camera output is BGR (or RGB) by default, but the Luckfox MIPI CSI camera outputs raw YUV formats (e.g. UYVY, NV12, NV21, etc.), which OpenCV does not automatically convert.
# v4l2-ctl -d /dev/video11 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture Multiplanar
[0]: 'UYVY' (UYVY 4:2:2)
Size: Stepwise 32x32 - 2304x1296 with step 8/8
[1]: 'NV16' (Y/CbCr 4:2:2)
[2]: 'NV61' (Y/CrCb 4:2:2)
[3]: 'NV21' (Y/CrCb 4:2:0)
[4]: 'NV12' (Y/CbCr 4:2:0)
[5]: 'NM21' (Y/CrCb 4:2:0 (N-C))
[6]: 'NM12' (Y/CbCr 4:2:0 (N-C))
I slight modified the code in the sample for debugging:
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include <unistd.h> // sleep()
int main()
fprintf(stderr, "Still Image Capture Example..\n");
cv::VideoCapture cap;
cap.set(cv::CAP_PROP_FRAME_WIDTH, 320);
cap.set(cv::CAP_PROP_FRAME_HEIGHT, 240);
cap.open(0);
if (!cap.isOpened())
fprintf(stderr, "ERROR: Cannot open camera.\n");
return -1;
else
fprintf(stderr, "Opened camera..\n");
const int w = cap.get(cv::CAP_PROP_FRAME_WIDTH);
const int h = cap.get(cv::CAP_PROP_FRAME_HEIGHT);
fprintf(stderr, "Image Dimensions: %d x %d\n", w, h);
cv::Mat bgr[9];
for (int i = 0; i < 9; i++)
cap >> bgr[i];
if (bgr[i].empty())
fprintf(stderr, "ERROR: Frame %d is empty\n", i);
return -1;
fprintf(stderr, "Captured frame %d: type = %d, channels = %d\n",
i, bgr[i].type(), bgr[i].channels());
// Save intermediate frames for debugging
std::string filename = "frame_" + std::to_string(i) + ".jpg";
cv::imwrite(filename, bgr[i]);
sleep(1);
cap.release();
// combine into big image
cv::Mat out(h * 3, w * 3, CV_8UC3);
bgr[0].copyTo(out(cv::Rect(0, 0, w, h)));
bgr[1].copyTo(out(cv::Rect(w, 0, w, h)));
bgr[2].copyTo(out(cv::Rect(w * 2, 0, w, h)));
bgr[3].copyTo(out(cv::Rect(0, h, w, h)));
bgr[4].copyTo(out(cv::Rect(w, h, w, h)));
bgr[5].copyTo(out(cv::Rect(w * 2, h, w, h)));
bgr[6].copyTo(out(cv::Rect(0, h * 2, w, h)));
bgr[7].copyTo(out(cv::Rect(w, h * 2, w, h)));
bgr[8].copyTo(out(cv::Rect(w * 2, h * 2, w, h)));
if (!cv::imwrite("out.jpg", out))
fprintf(stderr, "ERROR: Failed to write out.jpg\n");
return -1;
Any help would be appreciated.
