and build the sdk will meet the error below.my contaoiner's glibc version is 2.35
```bash
==sysdrv== build buildroot
test -d /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6 || (\
mkdir -p /home/luckfox-pico/sysdrv/source/buildroot ;\
tar xzf /home/luckfox-pico/sysdrv/tools/board/buildroot/buildroot-2023.02.6.tar.gz -C /home/luckfox-pico/sysdrv/source/buildroot ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/luckfox_pico_defconfig /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/configs/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/luckfox_pico_w_defconfig /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/configs/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/busybox.config /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/package/busybox/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/hcitool_patch/0001-Fixed-header-file-errors.patch /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/package/bluez5_utils/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/hcitool_patch/0002-Fix-build-errors.patch /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/package/bluez5_utils/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/hcitool_patch/0003-fix-compat-wordexp.patch /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/package/bluez5_utils/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/mpv_patch/0002-change-j1.patch /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/package/mpv/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/busybox_patch/0009-busybox-support-chinese-display-in-terminal.patch /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/package/busybox/ ;\
cp /home/luckfox-pico/sysdrv/tools/board/buildroot/busybox_patch/0010-halt-Support-rebooting-with-arg.patch /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/package/busybox/ ;\
make ARCH=arm CROSS_COMPILE=arm-rockchip830-linux-uclibcgnueabihf- luckfox_pico_defconfig -C /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6
make[1]: Entering directory '/home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6'
/home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/build/buildroot-config/conf: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.38' not found (required by /home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6/output/build/buildroot-config/conf)
make[1]: *** [Makefile
make[1]: Leaving directory '/home/luckfox-pico/sysdrv/source/buildroot/buildroot-2023.02.6'
make: *** [Makefile:614: buildroot] Error 2
make: Leaving directory '/home/luckfox-pico/sysdrv'
[build.sh:error] Running build_rootfs failed!
[build.sh:error] exit code 2 from line 856:
[build.sh:info] make rootfs -C ${SDK_SYSDRV_DIR}
