+ ln -rsf kernel/zboot.img /home/harley/luckfox-lyra/output/firmware/boot.img
Not Found io-domains in kernel/arch/arm/boot/dts/rk3506g-luckfox-lyra.dts
Running mk-kernel.sh - build_kernel succeeded.
Start building rootfs(buildroot)
Start building buildroot(2024.02)
Your network is not able to access sources.buildroot.net!
Please retry later (it could be down for a while) or setup a VPN to bypass the GFW.
Unset RK_NETWORK_CHECK in the SDK config to continue...
ERROR: Running /home/harley/luckfox-lyra/device/rockchip/common/scripts/mk-rootfs.sh - build_buildroot failed!
ERROR: exit code 1 from line 16:
"$RK_SCRIPTS_DIR/mk-buildroot.sh" $RK_BUILDROOT_CFG "$IMAGE_DIR"
ERROR: call stack:
mk-rootfs.sh: build_buildroot(16)
mk-rootfs.sh: build_hook(311)
mk-rootfs.sh: main(340)
ERROR: Running /home/harley/luckfox-lyra/device/rockchip/common/build-hooks/99-all.sh - build_all failed!
ERROR: exit code 1 from line 21:
"$RK_SCRIPTS_DIR/mk-rootfs.sh"
ERROR: call stack:
99-all.sh: build_all(21)
99-all.sh: build_hook(136)
build-helper: try_func(63)
build-helper: try_hook(96)
build-helper: source(165)
99-all.sh: main(147)
ERROR: Running /home/harley/luckfox-lyra/device/rockchip/common/build-hooks/99-all.sh - try_func build_hook all failed!
ERROR: exit code 1 from line 67:
build_hook
ERROR: call stack:
build-helper: try_func(67)
