Sometimes when running
"RK_MPI_SYS_Exit();"Code: Select all
cap.release()Any ideas why this happen and how to fix this?
Sincerely
cap.release()Code: Select all
#!/bin/sh
PIDFILE=/var/run/rklunch.pid
run_loop() {
interval=$1
[ -z "$interval" ] && interval=10 # default to 10 if not provided
trap "exit 0" TERM INT # exit cleanly if killed
while true; do
RkLunch.sh
sleep "$interval"
RkLunch-stop.sh
done
case "$1" in
start)
shift # drop "start"
interval=$1
if [ -f "$PIDFILE" ] && kill -0 "$(cat "$PIDFILE")" 2>/dev/null; then
echo "Servcie is already running (PID $(cat "$PIDFILE"))"
exit 1
fi
echo "Starting RkLunch service with interval=${interval:-10}s..."
# Make sure rkipc is closed before starting the loop
RkLunch-sh.stop
run_loop "$interval" &
echo $! > "$PIDFILE"
stop)
echo "Stopping RkLunch service..."
if [ -f "$PIDFILE" ]; then
if kill -0 "$(cat "$PIDFILE")" 2>/dev/null; then
kill "$(cat "$PIDFILE")"
fi
rm -f "$PIDFILE"
else
echo "No PID file, not running?"
fi
restart)
$0 stop
sleep 1
$0 start "$2"
status)
echo "RkLunch is running (PID $(cat "$PIDFILE"))"
else
echo "RkLunch is not running"
fi
echo "Usage: $0 {start [interval]|stop|restart [interval]|status}"
exit 1
esac
exit 0
[video.c][rkipc_ivs_get_results]:get chn 0 fail -1609269234
[ 494.161519] vepu_pp_destroy_chn 0
RTDeviceV4L2 18:17:01-481 {ispStreamOff :521} do ispStreamOff start
RTDeviceV4L2 18:17:01-508 {ispStreamOff :532} do ispStreamOff done
[ 494.161844] rockit isp stream off
RTDeviceV4L2 18:17:01-508 {close :374} do RTDeviceV4L2 close
[ 494.190090] mpp_vcodec: 162: destroy chan 0 hnd f9954f56 online 0 combo -1 mst -1
[osd.c][osd_time_server]:exit
[ 494.206724] mpp_vcodec: 188: destroy chan 0 done
MpiAdapterEncode 18:17:01-527 {ma_encode_destroy :2347} unmap ptr: 0xa4252000
RTDeviceV4L2 18:17:01-527 {ispStreamOff :521} do ispStreamOff start
[ 494.207451] rockit isp stream off
RTDeviceV4L2 18:17:01-548 {ispStreamOff :532} do ispStreamOff done
[ 494.229672] mpp_vcodec: 162: destroy chan 1 hnd 837fab3f online 0 combo -1 mst -1
RTDeviceV4L2 18:17:01-548 {close :374} do RTDeviceV4L2 close
[ 494.229929] mpp_vcodec: 188: destroy chan 1 done
MpiAdapterEncode 18:17:01-550 {ma_encode_destroy :2347} unmap ptr: 0xa35a8000
[ 494.230287] rockit isp stream off
RTDeviceV4L2 18:17:01-550 {ispStreamOff :521} do ispStreamOff start
[ 494.267068] rkcif-mipi-lvds: stream[0] start stopping, total mode 0x2, cur 0x2
[ 494.305801] rockchip-mipi-csi2 mipi0-csi2: stream off, src_sd: 6f87ec3d, sd_name:rockchip-csi2-dphy0
CAMHW:K:camId:0, notify_isp_stream_status off
[ 494.305826] rockchip-mipi-csi2 mipi0-csi2: stream OFF
RTDeviceV4L2 18:17:01-627 {ispStreamOff :532} do ispStreamOff done
[ 494.305855] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
RTDeviceV4L2 18:17:01-627 {close :374} do RTDeviceV4L2 close
[ 494.305876] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0, ret 0
[video.c][rkipc_pipe_jpeg_deinit]:RK_MPI_VENC_DestroyChn success
[ 494.306079] rkcif-mipi-lvds: stream[0] stopping finished, dma_en 0x0
[DEBUG rtsp_demo.c:645:rtsp_del_session] del session path: /live/0
[ 494.306092] rkcif-mipi-lvds: stream[0] start stopping, total mode 0x0, cur 0x2
[DEBUG rtsp_demo.c:645:rtsp_del_session] del session path: /live/1
[ 494.306100] rkcif-mipi-lvds: stream[0] stopping finished, dma_en 0x0
[isp.c][rk_isp_deinit]:cam_id is 0
[ 494.307508] mpp_vcodec: 162: destroy chan 4 hnd 15eeba9e online 0 combo -1 mst -1
[isp.c][rk_isp_deinit]:rk_aiq_uapi2_sysctl_stop enter
[ 494.307745] mpp_vcodec: 188: destroy chan 4 done
XCORE:K:cid[0] rk_aiq_uapi_sysctl_stop success.
[ 494.313814] stream_cif_mipi_id1: close video, entity use_count 0
[isp.c][rk_isp_deinit]:rk_aiq_uapi2_sysctl_deinit enter
[ 494.313861] stream_cif_mipi_id0: close video, entity use_count 1
MessageParser process loop exit!
[ 494.314268] stream_cif_mipi_id0: s_power 0, entity use_count 0
IPCSERVER:K:cid[0] Deinit success
[ 494.317167] vsys_release, 27
XCORE:K:cid[0] rk_aiq_uapi_sysctl_deinit_locked success.
[ 494.317181] vrgn_release, 123
[isp.c][rk_isp_deinit]:rk_aiq_uapi2_sysctl_deinit exit
[ 494.317219] vi_release 99
RKSockServer 18:17:02-151 {start :162} accept failed
(null) 18:17:03-152 {monitor_log_level :190} monitor_log_level quit
[ntp.c][rkipc_ntp_update]:connect error
[param.c][rk_param_deinit]:rk_param_deinit
[ 494.317282] venc_release 51
[ 497.445273] sdio_err:<aicwf_sdio_tx_msg,1964>: aicwf_sdio_send_pkt fail-110
[ 500.965243] cmd timed-out
[ 500.965328] wlan error reset flow.
[ 500.965338] send event.
[ 500.965408] wlan error event send.
[ 500.965424] tkn[852] flags:0032 result: -4 cmd:4103-SCANU_VENDOR_IE_REQ - reqcfm(4104-SCANU_VENDOR_IE_CFM)
[ 500.965438] cmd queue crashed
[ 504.008368] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 504.023705] mmc_host mmc0: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[ 507.045330] blk_update_request: I/O error, dev mmcblk0, sector 1135362 op 0x1:(WRITE) flags 0x0 phys_seg 6 prio class 0
[ 507.045364] EXT4-fs warning (device mmcblk0p6): ext4_end_bio:351: I/O error 10 writing to inode 13 starting block 567705)
[ 507.045383] Buffer I/O error on device mmcblk0p6, logical block 9825
[ 507.045392] Buffer I/O error on device mmcblk0p6, logical block 9826
[ 507.045399] Buffer I/O error on device mmcblk0p6, logical block 9827
[ 507.045409] Buffer I/O error on device mmcblk0p6, logical block 9828
[ 507.045428] Buffer I/O error on device mmcblk0p6, logical block 9829
[ 507.045437] Buffer I/O error on device mmcblk0p6, logical block 9830
[ 507.045444] Buffer I/O error on device mmcblk0p6, logical block 9831
[ 507.045452] Buffer I/O error on device mmcblk0p6, logical block 9832
[ 507.045462] Buffer I/O error on device mmcblk0p6, logical block 9833
[ 507.045470] Buffer I/O error on device mmcblk0p6, logical block 9834
[ 507.147194] JBD2: Detected IO errors while flushing file data on mmcblk0p6-8
[ 515.928870] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 515.944205] mmc_host mmc0: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[ 518.965334] blk_update_request: I/O error, dev mmcblk0, sector 67400 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 518.965364] Buffer I/O error on dev mmcblk0p5, logical block 33, lost async page write
MpiHwInterface 21:19:18-120 {reset :356} reset
RTAllocatorDma 21:19:18-120 {freeDmaBuffer :263} free buffer(ptr=0xc89a8, handle=000, fd=053, data=(nil), size=0)
MpiHwInterface 21:19:18-120 {destroy :115} destroy
MpiAdapterEncode 21:19:18-123 {ma_encode_destroy :2347} unmap ptr: 0xa48db000
MpiHwInterface 21:19:18-123 {~MpiHwInterface :038} ~MpiHwInterface
MpiHwInterface 21:19:18-124 {destroy :115} destroy
cmpi 21:19:18-124 {venc_destroy_chn :212} VENC_IOCTL_NODE_DELETE
cmpi 21:19:19-125 {stopRuntime :1113} VVI_IOCTL_NODE_STOP: dev:0, chn:0
cmpi 21:19:19-126 {streamOff :1215} start dev:0 chn:0 stream off
RTDeviceV4L2 21:19:19-126 {ispStreamOff :521} do ispStreamOff start
