We have produced a camera module for Luckfox Pico Max board. The sensor supports linear 12-bit and HDRx3 10-bit mode.
While linear mode is working properly, HDRx3 doesn't work at all.
May I know if RV1106 supports HDRx3 cameras? Or is there any document and sample code about HDRx3 in RV1106?
Thanks.
RV1106 HDR camera support
Hello, the non-third-party camera adapter does not provide technical support. For the RV1106, the ISP supports the highest two-frame HDR. You can check the kernel logs to understand the cause of the problem.
