USB Sound
Posted: 2025-08-09 11:48
by SBrody
Hi, just bought a Luckfox Lyra Ultra RK3506B and I am having a problem using a USB sound device. From research on the internet all I can find is that the USB sound has to be enabled in the Kernel but I am not sure how to do that. Any advise or help would be greatly appreciated. With the command lsusb I get back Bus 001 Device 003: ID 0d8c:0012 C-Media Electronics, Inc. USB Audio Device.
Kind regards
Steve
Re: USB Sound
Posted: 2025-08-23 10:13
Hello, you can execute "./build.sh kernelconfig" in the SDK to search for "SND_USB_AUDIO" and enable the support. By default, it will be added to the rootfs in the form of a module. You need to fully compile the entire system and re-flash it.
Re: USB Sound
Posted: 2025-09-04 10:50
by torusww
I have same question, but I use ubuntu image . How can I do ?
thanks
Re: USB Sound
Posted: 2025-09-05 1:19
The USB sound card function is controlled by the kernel driver and is independent of the rootfs used. This method can also be used even when using a non-buildroot system.
