adding zram to buildroot
Posted: 2025-09-15 15:42
by ibrahim
Hi
I am new to luckfox and buildroot , i was trying to add some libraries to the luckfox pic max buildroot image, i managed to add some but i couldn't make zram works,
1- zramctl is already marked inside the util-linux
2- i also did this overlay in the photo attached
what else i can do, if you please guide me to something to make it work with some nice steps as i am new to this
many thanks,
Re: adding zram to buildroot
Posted: 2025-09-20 10:12
Hello, for Luckfox Pico, the default setting does not support loading kernel modules using modprobe. It is recommended that you directly use insmod to load the modules. It would be best to ensure that each command runs correctly before considering writing or modifying the startup script S90zram
Posted: 2025-09-22 10:12
by ibrahim
Crocodile wrote: 2025-09-20 10:12 Hello, for Luckfox Pico, the default setting does not support loading kernel modules using modprobe. It is recommended that you directly use insmod to load the modules. It would be best to ensure that each command runs correctly before considering writing or modifying the startup script S90zram
thanks for this,
I found another script on gemini that says it resolves this matter of modprobe and insmod
#!/bin/sh
case "$1" in
    start)
        echo "Enabling zram..."
        # Get total system memory in KB
        TOTAL_MEM_KB=$(awk '/MemTotal/ {print $2}' /proc/meminfo)
        # Allocate 50% of memory to zram
        ZRAM_SIZE_KB=$(( TOTAL_MEM_KB / 2 ))
        modprobe zram
        echo $ZRAM_SIZE_KB > /sys/block/zram0/disksize
        mkswap /dev/zram0
        swapon /dev/zram0
        echo "zram enabled with size $(( ZRAM_SIZE_KB / 1024 ))MB"
    stop)
        echo "Disabling zram..."
        swapoff /dev/zram0
        echo 1 > /sys/block/zram0/reset
        modprobe -r zram
        echo "Usage: $0 {start|stop}"
        exit 1
esac
it says echo 1 > /sys/block/zram0/disksize, directly communicates with the kernel instead of relying on external tools.
so what do you think about it ? I tried it and it seems to work but I don't know if it is ok or not to run it like this ?
thanks
