RV1103 parallel computing with Cortex A7 and RISC-V
  • Hello, for RV1103, the MCU is set to be used for assisting in the startup and ISP initialization. During the rapid startup process, RTThread is compiled and run. Rockchip does provide the related development environment $SDK/sysdrv/source/mcu, but the usage materials mainly explain how to adapt it for other sensor initialization. If you want to implement a regular AMP application, you may need to conduct extensive research on the source code.
