你好
我用luckfox pico max连接一颗evs摄像头,希望在板子ubuntu环境下用v4l2-ctl抓取摄像头的raw数据。MIPI长宽配置为4096和235,目前有以下问题,可以帮忙看看设备树配置是否有误(需要抓取摄像头mipi的原始数据,不能经过任何ISP),请问可能原因是什么呀
1)当用sudo v4l2-ctl -d /dev/video0 --set-fmt-video=width=4096,height=235,pixelformat=RG10 --stream-mmap=4 --stream-to=mp333.raw --stream-count=50 --stream-skip=1 --stream-poll时候会报错selest timeout
2)当用sudo v4l2-ctl -d /dev/video0 --set-fmt-video=width=1024,height=235,pixelformat=RG10 --stream-mmap=4 --stream-to=mp333.raw --stream-count=50 --stream-skip=1 --stream-poll时候可以抓取数据,但是检查数据发现格式不对
目前我做了以下调试:
1)dmesg 可以检测到摄像头probe success,且可以读取到摄像头的chip id
2)相同的硬件接到手里另一块正点原子RK3568板能够正确读取数据
3) luckfox pico max板sudo media-ctl -p -d /dev/media0打印拓扑结构如下:
pico@luckfox:~$ sudo media-ctl -p -d /dev/media0
[sudo] password for pico:
Media controller API version 5.10.160
Media device information
driver rkcif
model rkcif-mipi-lvds
serial
bus info
hw revision 0x0
driver version 5.10.160
Device topology
- entity 1: stream_cif_mipi_id0 (1 pad, 11 links)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "rockchip-mipi-csi2":1 [ENABLED]
<- "rockchip-mipi-csi2":2 []
<- "rockchip-mipi-csi2":3 []
<- "rockchip-mipi-csi2":4 []
<- "rockchip-mipi-csi2":5 []
<- "rockchip-mipi-csi2":6 []
<- "rockchip-mipi-csi2":7 []
<- "rockchip-mipi-csi2":8 []
<- "rockchip-mipi-csi2":9 []
<- "rockchip-mipi-csi2":10 []
<- "rockchip-mipi-csi2":11 []
- entity 5: stream_cif_mipi_id1 (1 pad, 11 links)
device node name /dev/video1
pad0: Sink
<- "rockchip-mipi-csi2":1 []
<- "rockchip-mipi-csi2":2 [ENABLED]
- entity 9: stream_cif_mipi_id2 (1 pad, 11 links)
device node name /dev/video2
pad0: Sink
<- "rockchip-mipi-csi2":3 [ENABLED]
- entity 13: stream_cif_mipi_id3 (1 pad, 11 links)
device node name /dev/video3
pad0: Sink
<- "rockchip-mipi-csi2":4 [ENABLED]
- entity 17: rkcif_scale_ch0 (1 pad, 11 links)
device node name /dev/video4
pad0: Sink
<- "rockchip-mipi-csi2":5 [ENABLED]
- entity 21: rkcif_scale_ch1 (1 pad, 11 links)
device node name /dev/video5
pad0: Sink
<- "rockchip-mipi-csi2":6 [ENABLED]
- entity 25: rkcif_scale_ch2 (1 pad, 11 links)
device node name /dev/video6
pad0: Sink
<- "rockchip-mipi-csi2":7 [ENABLED]
- entity 29: rkcif_scale_ch3 (1 pad, 11 links)
device node name /dev/video7
pad0: Sink
<- "rockchip-mipi-csi2":8 [ENABLED]
- entity 33: rkcif_tools_id0 (1 pad, 11 links)
device node name /dev/video8
pad0: Sink
<- "rockchip-mipi-csi2":9 [ENABLED]
- entity 37: rkcif_tools_id1 (1 pad, 11 links)
device node name /dev/video9
pad0: Sink
<- "rockchip-mipi-csi2":10 [ENABLED]
- entity 41: rkcif_tools_id2 (1 pad, 11 links)
device node name /dev/video10
pad0: Sink
<- "rockchip-mipi-csi2":11 [ENABLED]
- entity 45: rockchip-mipi-csi2 (12 pads, 122 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:unknown/4096x235 field:none
crop.bounds:(0,0)/4096x235
crop:(0,0)/4096x235]
<- "rockchip-csi2-dphy0":1 [ENABLED]
pad1: Source
-> "stream_cif_mipi_id0":0 [ENABLED]
-> "stream_cif_mipi_id1":0 []
-> "stream_cif_mipi_id2":0 []
-> "stream_cif_mipi_id3":0 []
-> "rkcif_scale_ch0":0 []
-> "rkcif_scale_ch1":0 []
-> "rkcif_scale_ch2":0 []
-> "rkcif_scale_ch3":0 []
-> "rkcif_tools_id0":0 []
-> "rkcif_tools_id1":0 []
-> "rkcif_tools_id2":0 []
pad2: Source
-> "stream_cif_mipi_id0":0 []
-> "stream_cif_mipi_id1":0 [ENABLED]
pad3: Source
-> "stream_cif_mipi_id2":0 [ENABLED]
pad4: Source
-> "stream_cif_mipi_id3":0 [ENABLED]
pad5: Source
-> "rkcif_scale_ch0":0 [ENABLED]
pad6: Source
-> "rkcif_scale_ch1":0 [ENABLED]
pad7: Source
-> "rkcif_scale_ch2":0 [ENABLED]
pad8: Source
-> "rkcif_scale_ch3":0 [ENABLED]
pad9: Source
-> "rkcif_tools_id0":0 [ENABLED]
pad10: Source
-> "rkcif_tools_id1":0 [ENABLED]
pad11: Source
-> "rkcif_tools_id2":0 [ENABLED]
- entity 58: rockchip-csi2-dphy0 (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
[fmt:unknown/4096x235@10000/10000 field:none]
<- "m00_b_genx320 4-003c":0 [ENABLED]
pad1: Source
-> "rockchip-mipi-csi2":0 [ENABLED]
- entity 63: m00_b_genx320 4-003c (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
-> "rockchip-csi2-dphy0":0 [ENABLED]
luckfox pico max板连接evs摄像头
您好 RV1106 的ISP捕获水平分辨率有限制,默认配置不能超过 3072,虽然仅需要获取RAW,但是ISP也是驱动初始化的一部分,可以尝试修改设备树让两个ISP作用于一个sensor
有验证过的最大水平分辨率是3684,不确定能否支持4096
&rkisp{
rockchip,unite-en;
