[RV1106] How to integrate new RGB LCD Screen to Luckfox Pico Ultra BW
I have Luckfox Pico Ultra BW board, how can i integrate this LCD Type with the board. LCD Datasheet bellow.
- Attachments
YXR44-276C.pdf (1.36 MiB)Downloaded 148 times
Hello, the Luckfox Pico Ultra does not have sufficient SPI pins. If the RGB screen requires SPI to send initialization commands to be driven, it can only be accomplished by redesigning the adapter board and using the MCU to assist in the screen initialization. In addition, you also need the timing information of the screen (hback, hfront, etc.) for modifying the device tree configuration. This information is usually provided by the screen manufacturer.
