On boot up RkLunch.sh runs and I can connect with VLC on: rtsp://192.168.1.206/live/0
I can then stop the streaming service with RkLunch-stop.sh:
RkLunch-stop.sh
Stop Application ...
killall: udhcpc: no process killed
rkipc exit
ls: /oem/usr/etc/init.d/S??*: No such file or directory
However, if I try to restart streaming the system hangs
rtsp streamq_alloc size is 1753484
rtsp streamq_alloc size is 59884
[DEBUG rtsp_demo.c:480:rtsp_new_session] add session path: /live/1
RKViChn 02:35:04-011 {prepareRuntime :354} ---------------------------------------------------------
RKViChn 02:35:04-012 {prepareRuntime :356} vi version: 1.22, name:vvi
RKViChn 02:35:04-012 {prepareRuntime :357} rockit-ko version: vmpi:28ee389dbc33
RKViChn 02:35:04-013 {prepareRuntime :358} rockit-ko building: -2024-05-24-18:15:06
RKViChn 02:35:04-013 {prepareRuntime :359} ---------------------------------------------------------
cmpi 02:35:04-013 {prepareRuntime :378} mb pool create success, MBCnt= 2
RTIsp3x 02:35:04-016 {ispInitDevice :591} sensor name = m00_b_sc3336 4-0030
cmpi 02:35:04-023 {createRuntime :634} >>>>>>>>> Sensor link info dump: <<<<<<<<<
cmpi 02:35:04-024 {createRuntime :636} vicap media name : /dev/media0
cmpi 02:35:04-025 {createRuntime :637} vicap model name : rkcif-mipi-lvds
cmpi 02:35:04-027 {createRuntime :638} camera id : 0
cmpi 02:35:04-027 {createRuntime :639} sensor name : m00_b_sc3336 4-0030
cmpi 02:35:04-028 {createRuntime :641} stream_cif_mipi_id0 video name: /dev/video0
cmpi 02:35:04-028 {createRuntime :642} stream_cif_mipi_id1 video name: /dev/video1
cmpi 02:35:04-029 {createRuntime :643} stream_cif_mipi_id2 video name: /dev/video2
cmpi 02:35:04-029 {createRuntime :644} stream_cif_mipi_id3 video name: /dev/video3
cmpi 02:35:04-029 {createRuntime :646} sensor raw width : 2304
cmpi 02:35:04-029 {createRuntime :647} sensor raw height : 1296
cmpi 02:35:04-029 {createRuntime :648} ---------------------------------------------------------
cmpi 02:35:04-030 {createRuntime :654} isp media name : /dev/media1
cmpi 02:35:04-030 {createRuntime :655} isp model name : rkisp0
cmpi 02:35:04-030 {createRuntime :656} isp driver name : rkisp-vir0
cmpi 02:35:04-030 {createRuntime :657} isp dev name : /dev/v4l-subdev3
cmpi 02:35:04-031 {createRuntime :659} isp rawrd0_m_path : /dev/video17
cmpi 02:35:04-031 {createRuntime :660} isp rawrd1_l_path :
cmpi 02:35:04-031 {createRuntime :661} isp rawrd2_s_path : /dev/video18
cmpi 02:35:04-031 {createRuntime :664} mainpath video name : /dev/video11
cmpi 02:35:04-031 {createRuntime :665} selfpath video name : /dev/video12
cmpi 02:35:04-031 {createRuntime :666} bypasspath video name : /dev/video13
cmpi 02:35:04-032 {createRuntime :667} sensor link type : 2
cmpi 02:35:04-032 {createRuntime :668} sensor is united : 0
cmpi 02:35:04-032 {createRuntime :672} ---------------------------------------------------------
cmpi 02:35:04-033 {createRuntime :711} [non-WRAP MODE]: buff size = 4478976
RTIsp3x 02:35:04-049 {ispInitDevice :591} sensor name = m00_b_sc3336 4-0030
RTDeviceV4L2 02:35:04-056 {open :137} cameraIndex:0, entityName:rkisp_mainpath
RTDeviceV4L2 02:35:04-059 {open :143} open video name(/dev/video11)
RKViChn 02:35:04-061 {setFrameRate :1469} [vi] dev(0) ch(0) illegal param s32SrcFrameRate(0) s32DstFrameRate(0)
RTDeviceV4L2 02:35:04-065 {ispCameraInfo :567} current device:/dev/video11 isn't compatible(cap:0x84201000) device,memoryType:4, retry:0
RTDeviceV4L2 02:35:04-066 {ispInitFormat :767} ioctl VIDIOC_S_FMT OK
cmpi 02:35:04-069 {start :1093} =========== vi Start startRuntime ===========
RTDeviceV4L2 02:35:04-069 {ispStreamOn :458} do ispStreamOn start
CAMHW:K:camId:0, notify_isp_stream_status on
RTDeviceV4L2 02:35:04-094 {ispStreamOn :511} do ispStreamOn done
[video.c][rk_video_set_frame_rate]:num is 25, den is 1
[video.c][rk_video_set_frame_rate]:old VI framerate is [-1:-1]
[video.c][rk_video_set_frame_rate]:new VI framerate is [25:25]
RKVencChannel 02:35:04-095 {setH265CuDqp :4003} pstCuDqp illegal param: u32CuDqp -6(expects range [0, 2])
MpiAdapterEncode 02:35:04-096 {ma_encode_create :1743} ringbuf buf_size 1495040
