Strange behavior of VSys and VBUS
Posted: 2025-10-07 14:54
In my Pro/Max board, I wanted to connect a mini USB printer. To do this, I enabled USB Printer support under Device Drivers → USB support → USB Printer support in the kernel configuration, and enabled USB in HOST mode through the DTS.
My board is powered by an external 5 V supply through the VSYS pin, but in this configuration the printer is never detected. After several tests, I switched the power input to the VBUS pin, and the printer started working correctly.
However, when powering through VBUS, the SD card is no longer mounted; when I switch back to VSYS, the SD card mounts properly again.
Could you tell me what is happening?
