apparently this touchscreen is not compatible with Omni3576.
Do you know which settings I should change in the RDK to get this touchscreen to work?
Kind regards,
Luc Segers
https://www.waveshare.com/9-dsi-touch-b.htm not compatible with Omni3576
https://www.waveshare.com/wiki/10.1-DSI-TOUCH-B this should work work with standard Image from Rockchip according the wiki.
This device is based on same chipsets as the 9 inch version. So I guess it is a matter of settings.
Could you guys point me in de right direction? Thank you!
Hi,We have recently updated our SDK to add support for this screen, but the pre-built image is not yet packaged. You can download the latest SDK (version 251118) and compile it following our tutorial.
