Hi! I have tried to study the different options of customizing the FW and somehow I got the situation that after power up the rv1103 does not recognise the magic button .
The good thing is that the command shell in uboot has 'download' command. In case the shell if off is there any other way to switch the the device to the download mode?
How to unbrick the RV1103 pico plus?
Hello, apart from powering on by long-pressing the boot button and entering the burning mode through commands, you can also short-circuit the clk pin of flsah to GND to burn the image in this way. However, use it with caution.
