Core1106 Voltage Range
  • Hello, the power supply voltage range for VBUS and VSYS is 4.5V to 5.5V. We do not recommend using voltages below this range. For instance, insufficient power supply can cause the wlan0 node of the Wi-Fi to fail to load successfully, or the screen may not light up properly. Therefore, we haven't conducted more tests in this regard. If you want to achieve the low power consumption effect by using 3.7V, we highly recommend that you conduct long-term tests under this working condition to ensure that the required peripherals are functioning properly. We are also looking forward to your feedback. Thank you.
