is it possible to configure Luckfox Pico Ultra W to work against IMX415 8MP at 8M@10fps or 8M@5fps?
And if yes, where and how I configure that?
Kind regards,
Arie
The attached file contains the maximum supported values for the 1106 data manual. Theoretically, it can support 8m at 15fps. When you use it, for example, when using v4l2-ctl, you can adjust the resolution parameters to achieve the desired result.
