正常编译下载后,linux kernel 启动失败 Luckfox Pico Ultra W
Posted: 2026-01-21 3:53
by huiminli
clear buf : 0
get attribute : 0
clear attribute : 0
set loopback mode : 0
vqe enable : 0
adec input file name : (null)
[ 3.847111] aicbsp_init
log_file = (nil)
[ 3.847131] RELEASE_DATE:2025_0410_b99ca8b6
RTVersion 13:22:32-057 {dump :064} ---------------------------------------------------------
[ 3.847178] aicbsp_resv_mem_init
RTVersion 13:22:32-057 {dump :065} rockit version: git-4720dc10a Tue Apr 30 15:47:55 2024 +0800
RTVersion 13:22:32-057 {dump :066} rockit building: built- 2024-04-30 15:53:43
RTVersion 13:22:32-057 {dump :067} ---------------------------------------------------------
(null) 13:22:32-058 {read_log_level :098} text is all=4
(null) 13:22:32-058 {read_log_level :100} module is all, log_level is 4
cmpi 13:22:32-065 {main :823} start running loop count = 0
(null) 13:22:32-066 {monitor_log_level :149} #Start monitor_log_level thread, arg:(nil)
cmpi 13:22:32-098 {test_init_mpi_ao :226} Set volume curve type: 0
cmpi 13:22:32-105 {commandThread :376} test info : mute = 0, volume = 50
cmpi 13:22:32-106 {sendDataThread :309} params->s32ChnIndex : 0
insmod: can't insert 'libaes.ko': invalid module format
[ 4.108207] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
[ 4.108232] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
[ 4.108241] aicbsp: aicbsp_platform_power_on
[ 4.146439] aicbsp: aicbsp_sdio_probe:1 vid:0xC8A1 did:0xC08D
[ 4.146635] aicbsp: aicbsp_sdio_probe:2 vid:0xC8A1 did:0xC18D
[ 4.146648] aicbsp: aicbsp_sdio_probe after replace:1
[ 4.146659] AICWFDBG(LOGINFO) aicwf_sdio_chipmatch USE AIC8800DC
[ 4.146664] the device is PRODUCT_ID_AIC8800DC
[ 4.146674] aicbsp: aicbsp_get_feature, set FEATURE_SDIO_CLOCK 50 MHz
[ 4.146681] aicbsp: aicwf_sdio_reg_init
[ 4.146873] aicbsp: Set SDIO Clock 50 MHz
[ 4.155120] AICWFDBG(LOGINFO) btenable = 1
[ 4.155142] AICWFDBG(LOGINFO) aicbsp: aicbsp_driver_fw_init, chip rev: 7
[ 4.155154] rwnx_load_firmware :firmware path = /oem/usr/ko/aic8800dc_fw/fw_patch_table_8800dc_u02.bin
[ 4.156336] file md5:34860725322202bfc2d80843297562ee
[ 4.156474] AICWFDBG(LOGDDR 306b9977f5 wesley.yao 23/12/21-09:28:37,fwver: v1.15
S5P1
4x
f967
rgef1
DDRConf2
DDR3, BW=16 Col=10 Bk=8 CS0 Row=14 CS=1 Size=256MB
924MHz
DDR bin out
U-Boot SPL board init
U-Boot SPL 2017.09 (Jan 20 2026 - 19:17:16)
unknown raw ID 0 0 0
Trying to boot from MMC2
Card did not respond to voltage select!
mmc_init: -95, time 20
spl: mmc init failed with error: -95
Trying to boot from MMC1
Best phase range 270-225 (29 len)
Successfully tuned phase to 68, used 3ms
ENVF: Primary 0x00000000 - 0x00008000
No misc partition
Trying fit image at 0x440 sector
## Verified-boot: 0
## Checking uboot 0x00200000 (lzma @0x00400000) ... sha256(a913f5ca0e...) + sha256(7c32617524...) + OK
## Checking fdt 0x00261190 ... sha256(9f596c5683...) + OK
Total: 382.953/417.303 ms
Jumping to U-Boot(0x00200000)
U-Boot 2017.09 (Jan 20 2026 - 19:17:16 -0800)
Model: Rockchip RV1106 EVB Board
MPIDR: 0xf00
PreSerial: 2, raw, 0xff4c0000
DRAM: 256 MiB
Sysmem: init
Relocation Offset: 0fd80000
Relocation fdt: 0edf9f78 - 0edfede8
CR: M/C/I
Using default environment
Re: 正常编译下载后,linux kernel 启动失败 Luckfox Pico Ultra W
Posted: 2026-01-23 2:16
您好,无线模组上电初始化的时候是整版功耗最高的时候,在AIC8800模组初始化的过程中重启大概率是因为供电不稳定,建议更换电源
