Luckfox Pico mini A Add flash
Good evening, I have a pico mini A and I wanted to add a flash, I read that the original model is: W25N01GVZEIR, I tried to install a W25N01GVZEIG but even by pressing boot with the SocToolKit software I can't read or get info from the flash (the card works perfectly and even from Ubuntu I can't recognize the spi flash when booting from SD) is it the wrong flash model or do I also have to make a hardware modification? Thanks
Hello, W25N01GVZEIR and W25N01GVZEIG can be Pin to Pin connected. Using SocToolKit without downloading the DownloadBin will prevent the Flash information from being read. It could also be that the image you are using does not support fspi or there is a soldering issue. I suggest burning the image first to test if it can be successfully burned.
