I'm currently developing an IoT device using the Core1106 (Core11060208).
I want to connect an Ethernet hub IC to the FEPHY without pulse transformer.
Is the FEPHY driver in Voltage Mode or Current Mode? Is direct connection with a capacitor possible, or will bias adjustment using pull-up resistors be necessary?
Also, please let me know if you have any recommended circuits or points to keep in mind.
Direct connection of the Ethernet hub IC to the FEPHY of Core1106
Hello, any unverified hardware design suggestions carry a risk of failure. If necessary, you can refer to the schematic diagrams of other models. We do not provide technical support or suggestions related to hardware design.
