LuckFox Pico Pi AW and EDS
  • If you need to test the pull-up/pull-down function, you can refer to the attached file for implementation using the read/write register method. GPIO1_B2 and GPIO1_B3 are the debug serial port pins that have been configured during the SPL stage and will not prompt as being occupied when entering the kernel.
    Downloaded 50 times
