PicoKVM highly sensitive/faulty USB-C port
Posted: 2026-04-26 19:29
I have purchased the Luckfox PicoKVM Lightweight IP KVM.
MY setup:
App versiom 0.1.2
System Version 0.1.6
Original USB-C Raspberry Pi USB to Type-C Power Supply Adapter 5.1V 3A (Connected to Luckfox splitter USB-C Power)
Lindy USB-A to USB-C data cable (Connected to Luckfox splitter USB-C Data) for dual power and data.
The original Luckfox USB-C splitter cable sits in the PicoKVM USB-C port slightly high so not flush (Is this normal)?
The PicoKVM USB-C port seems is faulty.
Every time the PicoKVM unit is moved even slightly, the unit reboots. I can confirm it is the splitter cable USB-C to PicoKVM USB-C port connection which is faulty so highly sensitive, causing the unit to reboot when the PicoKVM unit is even slightly moved during normal use/handling.
MY setup:
App versiom 0.1.2
