Luckfox pico max ethernet and sd card issue
Hello, i am using Luckfox Pico Max ,i cannot to my local network via ethernet or ssh,no sd card is using in usb image,and can i download SDK via adb connection without any sd card
1.Burn the image provided by the cloud drive:
https://drive.google.com/drive/folders/ ... drive_link
2.After the system boots up normally, check for the IP address.
3.Connect via SSH.
https://wiki.luckfox.com/Luckfox-Pico/S ... omax-login
If you have any further questions or concerns, feel free to ask at any time.
3.Connect via SSH.
I have tried this earlier it cannot be connected, our system have static ip,no dhcp and memory card also not showing after inserting it into the TF slot
If there is no dhcp, refer to this post
viewtopic.php?t=47&start=10
SD card image can be mounted:
My system ip is 192.168.0.35
Gateway-192.168.0.11
Subnet-255.255.255.0 static IP
1.What should my setting for Rockchip board so that i can access via SSH login?
2.I have downloaded the SDK for the build.sh how to install it in the board?
3.I have tried multiple SD card none of them are working?
1.Use the serial port to log in to the development board and comment out the udhcpc related parts in /oem/usr/bin/RkLunch.sh[email protected] wrote: ↑2024-03-19 11:27 My system ip is 192.168.0.35
2. Write a self-starting script to set a static IP
Autostart setting tutorial: https://wiki.luckfox.com/Luckfox-Pico/L ... -autostart
#! /bin/sh
check_ip_address(){
if ifconfig eth0 | grep -q "inet "; then
return 1
else
return 0
fi
static_ip()
while true; do
if check_ip_address; then
ifconfig eth0 192.168.0.35 netmask 255.255.255.0
route add default gw 192.168.0.11
echo "nameserver 8.8.8.8" > /etc/resolv.conf
fi
sleep 5
done
case $1 in
start)
echo "start"
static_ip &
stop)
echo "stop"
exit 1
esac
The SDK cannot be installed directly on the development board. The system of the Luckfox Pico series development board is compiled on the computer and then burned to the development board. Therefore, you need to build an environment on your computer that can compile the development board system, referred to as SDK (Software Development Kit - a set of software tools and tools).[email protected] wrote: ↑2024-03-19 11:27 2.I have downloaded the SDK for the build.sh how to install it in the board?
The SD card system supports the FAT32 format by default, and it can be detected by my test here.[email protected] wrote: ↑2024-03-19 11:27 3.I have tried multiple SD card none of them are working?
# No sh extension, so fork subprocess.
$i stop
esac
done
echo "Stop Application ..."
killall rkipc
killall udhcpc
cnt=0
while [ 1 ];
do
sleep 1
cnt=$(( cnt + 1 ))
if [ $cnt -eq 8 ]; then
echo "killall -9 rkipc"
Sir,which part i have to change,
After connecting ethernet cable ,Luckfox Pico Max cannot be conneted to internet.
Please suggest
$i stop
esac
done
killall rkipc
killall udhcpc
cnt=0
while [ 1 ];
do
sleep 1
cnt=$(( cnt + 1 ))
Please suggest
Hi, have you tried the methods provided above?
Eng38 wrote: ↑2024-03-20 2:421.Use the serial port to log in to the development board and comment out the udhcpc related parts in /oem/usr/bin/RkLunch.sh[email protected] wrote: ↑2024-03-19 11:27 My system ip is 192.168.0.35
Autostart setting tutorial: https://wiki.luckfox.com/Luckfox-Pico/L ... -autostartCode: Select all
#! /bin/sh check_ip_address(){ if ifconfig eth0 | grep -q "inet "; then return 1 else return 0 fi } static_ip() { while true; do if check_ip_address; then ifconfig eth0 192.168.0.35 netmask 255.255.255.0 route add default gw 192.168.0.11 echo "nameserver 8.8.8.8" > /etc/resolv.conf fi sleep 5 done } case $1 in start) echo "start" ifconfig eth0 192.168.0.35 netmask 255.255.255.0 route add default gw 192.168.0.11 echo "nameserver 8.8.8.8" > /etc/resolv.conf static_ip & ;; stop) echo "stop" ;; *) exit 1 ;; esac
Yes sir i have tried ,
I have changed the ip and subnet mask
commented out udhpc part
but network not connected
The rkipc related code in /oem/usr/bin/RkLunch.sh should also be commented, as follows:
# if [ -d "/oem/usr/share/iqfiles" ];then
# rkipc -a /oem/usr/share/iqfiles &
# else
# rkipc &
# fi
