Hello, I am experiencing the same issue with meson and intl as posted here:
viewtopic.php?t=82
However, I cannot follow instructions because disabling libglib2 is not possible.
I assume the issue comes from missing UCLIBC_HAS_LIBINTL=y option from uclibc configuration. I have found out that the file (buildroot)/package/uclibc/uClibc-ng.config has the required option set, however to my understanding buildroot has been configured to use external uClibc provided by the toolchain.
(toolchain)/arm-rockchip830-linux-uclibcgnueabihf/arm-rockchip830-linux-uclibcgnueabihf/sysroot/usr/lib/uclibc_nonshared.a
(toolchain)/arm-rockchip830-linux-uclibcgnueabihf/arm-rockchip830-linux-uclibcgnueabihf/sysroot/lib/libuClibc-1.0.31.so
Is it possible to build my own version of uClibc with intl enabled or solve the issue in other way?
meson build failed / missing ulibc configuration
Hello,rhoki wrote: ↑2024-03-19 17:01 Hello, I am experiencing the same issue with meson and intl as posted here:
viewtopic.php?t=82
The reason why libglib2 cannot be deselected may be due to your selection of options that depend on libglib2. This is a mechanism in Buildroot to ensure the proper functioning of features. Under <Luckfox-pico SDK>/sysdrv/source/buildroot/buildroot-2023.02.6/package, you'll find various libraries and related documentation files. You can refer to these to identify which library depends on libglib2.
./at-spi2-atk/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./at-spi2-core/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./atk/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./babeltrace2/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./bluez-alsa/Config.in:14: select BR2_PACKAGE_LIBGLIB2
./bluez-tools/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./bluez5_utils/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./brickd/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./bustle/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./cairomm/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./cairomm1_14/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./connman/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./connman-gtk/Config.in:18: select BR2_PACKAGE_LIBGLIB2
./cups-filters/Config.in:16: select BR2_PACKAGE_LIBGLIB2
./curlftpfs/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./cwiid/Config.in:27: select BR2_PACKAGE_LIBGLIB2
./dbus-glib/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./dbus-python/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./docker/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./easydbus/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./enchant/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./fluidsynth/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./freerdp/Config.in:15: select BR2_PACKAGE_LIBGLIB2
./fwts/Config.in:17: select BR2_PACKAGE_LIBGLIB2
./gamin/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./gconf/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./gcr/Config.in:11: select BR2_PACKAGE_LIBGLIB2
./gdk-pixbuf/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./gkrellm/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./glib-networking/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./glibmm/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./glibmm2_66/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./gmpc/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./gobject-introspection/Config.in:29: select BR2_PACKAGE_LIBGLIB2
./granite/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./gsettings-desktop-schemas/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./gssdp/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./gstreamer1/gst1-python/Config.in:11: select BR2_PACKAGE_LIBGLIB2
./gstreamer1/gstd/Config.in:11: select BR2_PACKAGE_LIBGLIB2
./gstreamer1/gstreamer1/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./gupnp/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./gupnp-av/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./gupnp-dlna/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./gvfs/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./irqbalance/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./irssi/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./janus-gateway/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./json-glib/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./kodi/Config.in:225: select BR2_PACKAGE_LIBGLIB2
./ksmbd-tools/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./latencytop/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./lensfun/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./libblockdev/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./libfm/Config.in:11: select BR2_PACKAGE_LIBGLIB2
./libfm-extra/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./libgdiplus/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./libgee/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./libglade/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./libgtk2/Config.in:15: select BR2_PACKAGE_LIBGLIB2
./libgtk3/Config.in:32: select BR2_PACKAGE_LIBGLIB2
./libgudev/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./libmanette/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./libmbim/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./libmediaart/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./libmms/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./libmpd/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./libnice/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./libostree/Config.in:11: select BR2_PACKAGE_LIBGLIB2
./libpeas/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./libqmi/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./libqrtr-glib/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./librsvg/Config.in:15: select BR2_PACKAGE_LIBGLIB2
./libsecret/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./libsigrok/Config.in:12: select BR2_PACKAGE_LIBGLIB2
./libsigrokdecode/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./libsoup/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./libvips/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./libvirt/Config.in:27: select BR2_PACKAGE_LIBGLIB2
./lttng-babeltrace/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./mc/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./mender-connect/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./menu-cache/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./miraclecast/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./modem-manager/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./nbd/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./neard/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./network-manager/Config.in:13: select BR2_PACKAGE_LIBGLIB2
./ofono/Config.in:12: select BR2_PACKAGE_LIBGLIB2
./openbox/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./openvmtools/Config.in:15: select BR2_PACKAGE_LIBGLIB2
./pango/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./pcmanfm/Config.in:12: select BR2_PACKAGE_LIBGLIB2
./pipewire/Config.in:40: select BR2_PACKAGE_LIBGLIB2
./polkit/Config.in:12: select BR2_PACKAGE_LIBGLIB2
./pulseaudio/Config.in:21: select BR2_PACKAGE_LIBGLIB2
./python-gobject/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./qemu/Config.in:27: select BR2_PACKAGE_LIBGLIB2
./qt5/qt5webengine/Config.in:44: select BR2_PACKAGE_LIBGLIB2
./rauc/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./restorecond/Config.in:10: select BR2_PACKAGE_LIBGLIB2
./rrdtool/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./shairport-sync/Config.in:34: select BR2_PACKAGE_LIBGLIB2
./shared-mime-info/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./slirp/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./slirp4netns/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./speechd/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./spice/Config.in:13: select BR2_PACKAGE_LIBGLIB2
./sshfs/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./syslog-ng/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./sysprof/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./tpm2-abrmd/Config.in:7: select BR2_PACKAGE_LIBGLIB2
./usbredir/Config.in:28: select BR2_PACKAGE_LIBGLIB2
./wireplumber/Config.in:8: select BR2_PACKAGE_LIBGLIB2
./wireshark/Config.in:12: select BR2_PACKAGE_LIBGLIB2
./wmctrl/Config.in:9: select BR2_PACKAGE_LIBGLIB2
./wpebackend-fdo/Config.in:14: select BR2_PACKAGE_LIBGLIB2
./xdg-dbus-proxy/Config.in:6: select BR2_PACKAGE_LIBGLIB2
./xen/Config.in:27: select BR2_PACKAGE_LIBGLIB2
Hope this helps.
Thank you for your answer. The package causing the issue was sshfs. The problem I was trying to solve was that debug builds of media and app take much more space than release. My idea was to mount <Luckfox-pico SDK>/output/out/oem to /oem over network. I can achieve similar results with nfs, or just shrink rootfs and enlarge oem partition and then copy the app binary via scp after every build. Sshfs is just more convenient.
