Luckfox 7inch touchscreen not working
Hi, display is working on the rpi4 only touchscreen is not working. Display flicker sometimes. Are there any settings to make it work
Could you please confirm if the touchscreen can be used for touch input when connected to the computer? If not, please check if the device can be recognized in the Device Manager of the system and try replacing the touchscreen cable. Also, kindly share your connection diagram. If the Raspberry Pi touchscreen is not responsive, may I ask which version of the system you are using?
