1. 保证成功安装了瑞芯微的驱动助手DriverAssitant(推荐使用Windows10或者Windows11)。 2. 下载烧录软件时关闭杀毒软件:
- 在下载烧录软件时,务必关闭杀毒软件,因为杀毒软件可能会误伤部分配置文件,导致 SocToolKit 无法正确识别 USB 设备。
- 选择质量良好的 Type-C 数据线至关重要。许多用户经验表明,连接质量差的线可能导致接触不良,进而影响 SocToolKit 对 USB 设备的正常识别。确保使用高品质的 Type-C 线,以提高连接的可靠性。
- 确保没有其他程序如虚拟机、手机助手等占用 USB 设备。这些程序可能导致 SocToolKit 无法访问 USB 设备。
- 在一些情况下,USB HUB 的兼容性可能导致 SocToolKit 无法正常识别 USB 设备,建议直接连到电脑上
When customers first receive the development board, they often encounter issues with SocToolKit not recognizing the USB device. Here are some common solutions:
1. Ensure successful installation of Rockchip's Driver Assistant (recommended for use with Windows 10 or Windows 11).
- Reference link:https://wiki.luckfox.com/Luckfox-Pico/L ... co-prepare
- When downloading flashing software, be sure to disable antivirus software, as it may mistakenly interfere with some configuration files, causing SocToolKit to fail to recognize the USB device correctly.
- Choosing a good-quality Type-C data cable is crucial. Many user experiences indicate that poor-quality cables may result in poor contact, thereby affecting SocToolKit's normal recognition of USB devices. Ensure the use of a high-quality Type-C cable to improve connection reliability.
- Ensure that no other programs, such as virtual machines or mobile assistants, are occupying the USB device. These programs may cause SocToolKit to be unable to access the USB device.
- In some cases, the compatibility of the USB HUB may cause SocToolKit to fail to recognize the USB device properly. It is recommended to connect directly to the computer.
